HP Compaq nx7000 Notebook PC - Removing and Replacing the Inverter Board
This document is provided to assist in removing and replacing the inverter board for the HP Compaq nx7000 Notebook PC.
Minimum skill level
The End-User must possess extensive product-specific knowledge and technical skill on how to service the system, and be familiar with the operating system.
Tools required
  • Small, Phillips-head P0 screwdrivers
  • Small, flat-bladed screwdriver or a flat-bladed alignment tool
Parts required
The replacement part number will vary depending on the inverter board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Display inverter board - For models with 15.4 in display
336994-001 (Original)
No
Summary of instructions
To view a video demonstrating the procedure for removing the inverter board, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select Inverter board from the menu on the upper left hand side of the screen.
Click here to view the inverter board removal video (right-click on the link to open in a new window/tab).
Inverter board removal
  2. Disconnect the display panel cable from the end of the inverter board.
  3. Disconnect the inverter cable from the end of the inverter board.
  4. Remove the two 5 mm P0 Phillips-head screws that secure the inverter board to the display panel.
  5. Use a flat-bladed tool to carefully pry each end of the inverter board off of its guide pin and slide it out from under the metal display panel tab.
  6. Place the inverter board in a static dissipative bag.
Inverter board replacement
  1. Remove the inverter board from the static dissipative bag.
  2. Use a flat-bladed tool to carefully pry each metal display panel tab up enough to allow sliding the ends of the inverter board under them and onto the guide pins.
  3. Replace the two 5 mm P0 Phillips-head screws that secure the inverter board to the display panel.
  4. Reconnect the inverter cable to the end of the inverter board.
  5. Reconnect the display panel cable to the end of the inverter board.
