    Fix HP Printer issue on macOS
HP Scanjet Professional 1000 Mobile Scanner - Specifications
This document contains regulatory information and product specifications for your scanner.
Scanner Specifications
Name
Scanner type
Duplex mobile scanner
Size
Width: 290 mm (11.41 in), Depth: 75 (2.95), Height: 50 mm (1.97 in)
0.674 kg (1.5 lbs)
Scanning element
Contact image sensor (CIS)
Interface
USB 2.0 high speed (compatible with USB 1.1)
Optical resolution
600 x 600 dpi hardware
Power consumption
For power consumption information, see the regulatory_supplement.pdf file on the HP Scanning Software CD.
Energy information
Hewlett-Packard printing and imaging equipment marked with the ENERGY STAR® logo is qualified to the U.S. Environmental Protection Agency’s ENERGY STAR specifications for imaging equipment. The following mark will appear on ENERGY STAR qualified imaging products:
Additional ENERGY STAR qualified imaging product model information is listed at: http://www.hp.com/go/energystar
System requirements
To view minimum and recommended system requirements, go to www.hp.com, select your country/region, search on your scanner model, and then search on datasheet.
Document specifications
Name
Minimum paper size
74 x 52 mm (2.9 x 2.1 in)
Maximum paper size
215.9 x 356 mm (8.5 x 14 in)
Minimum paper weight
50 g/m2 (13.3 lbs)
Maximum paper weight
120 g/m2 (32 lbs)
Environmental specifications
Name
Temperature
Operating the scanner: 10° to 35° C (50° to 95° F)
Storage: -40° to 65° C (-40° to 149° F)
Relative humidity
Operating the scanner: 10% to 80° C noncondensing 10° to 35° C(50° to 95° F)
Storage: up to 90% at 0° to 65° C (32° to 149° F)
In the presence of high electromagnetic fields, it is possible the output from the HP scanner may be slightly distorted.
HP is committed to providing our customers with information about the chemical substances in our products as needed to comply with legal requirements such as REACH (Regulation EC No. 1907/2006 of the European Parliament and the Council). A chemical information report for this product can be found at www.hp.com/go/reach.
Regulatory information
Regulatory Model Identification Number: For regulatory identification purposes your product is assigned a Regulatory Model Number. The Regulatory Model Number for your product is FCLSD-1002. This regulatory number should not be confused with the marketing name (HP Scanjet Professional 1000 mobile scanner) or product number (L2722A). Additional regulatory information about your scanner can be found on the regulatory_supplement.pdf file on the CD shipped with your product.
Disposal of Waste Equipment by Users in Private Households in the European Union
This symbol on the product or on its packaging indicates that this product must not be disposed of with your other household waste. Instead, it is your responsibility to dispose of your waste equipment by handing it over to a designated collection point for the recycling of waste electrical and electronic equipment. The separate collection and recycling of your waste equipment at the time of disposal will help to conserve natural resources and ensure that it is recycled in a manner that protects human health and the environment. For more information about where you can drop off your waste equipment for recycling, please contact your local city office, your household waste disposal service or the shop where you purchased the product.
