HP Scanjet Professional 1000 Mobile Scanner - Product support
Accessibility options on this scanner include the ability to enable and disable scanner buttons. To enable or disable scanner buttons, please follow these steps:
  1. After the HP Scanjet 1000 scanner driver has been installed successfully, the HP Button Utility icon will be displayed on the bottom-right corner of your system tray.
  2. Right-click the HP Button Utility icon and check Disable. To enable scanner buttons, uncheck Disable.
Getting assistance
In order to get the best results from your HP product, please consult the following HP support offerings:
  1. Review the troubleshooting chapter.
  2. See the HP online support website at www.hp.com/support, or contact your point of purchase. HP online support is available to all HP customers. It is the fastest source for up-to-date product information and expert assistance, including the following features:
    • Online chat and email access to qualified online support specialists.
    • Software, firmware, and driver updates for your product.
    • Valuable product and troubleshooting information for technical issues.
    • Proactive product updates, support alerts, and HP newsletters (available when you register your product).
  3. HP support by phone
    • Support options and fees vary by product, country/region, and language.
    • Fees and policies are subject to change without notice. Please see www.hp.com/support for the latest information.
  4. Post-warranty period
    After the limited warranty period, help is available online at www.hp.com/support.
  5. Extending or upgrading your warranty
    If you would like to extend or upgrade the product’s warranty, please contact your point of purchase or see the HP Care Pack Services at www.hp.com/support.
  6. If you already purchased an HP Care Pack Service, please check the support conditions in your contract.
Where to get additional information
There are several sources of information that describe using the scanner and the scanning software.
HP Scanjet 1000 driver help
The HP Scanjet 1000 Scanner Driver Help explains how to use HP Scanjet 1000 scanner driver features such as removing color and changing basic scanning settings.
To open HP Scanjet 1000 Scanner Driver Help, follow these steps:
  1. Start your TWAIN-compliant scanning software application.
  2. Select the HP Scanjet 1000 TWAIN data source. Different applications provide different methods for displaying the TWAIN user interface. It is often accomplished by selecting Scanner Settings or Acquire. The HP Scanjet 1000 TWAIN user interface will be displayed.
  3. Click the Help button (the question mark in the upper right corner of the title bar) or press the F1 function key.
Technical resources
See www.hp.com/support for updated information about the scanner.
Country: Flag Bulgaria
