HP Compaq nc6000 Notebook PC - Removing and Replacing the Battery
This document is provided to assist in removing and replacing the battery for the HP Compaq nc6000 Notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the battery that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Battery (Primary) - 6-cell lithium-ion (Li-Ion), 11.1 VDC, 4.4 Ah, 48 Wh
346886-001 (Original)
No
Battery (Primary) - 8-cell lithium-ion (Li-Ion), 14.4 VDC, 4.4 Ah, 63 Wh (MG 1.3)
338669-001 (Original)
No
Summary of instructions
To view a video demonstrating the procedure for removing the battery, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Battery from the menu on the upper left hand side of the screen.
Click here to view the battery removal video (right-click on the link to open in a new window/tab).
Battery removal
  2. Slide and hold the battery release latch to the unlock position.
  3. Use your finger to grasp the battery bezel and slide the battery out of the battery bay.
Battery replacement
  1. Slide the battery into the battery bay until the battery release latch clicks.
