HP Compaq nc6230 Notebook - Removing and Replacing the Primary Memory Board
This document is provided to assist in removing and replacing the primary memory board for the HP Compaq nc6230 Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
  • Small, Phillips-head P0 screwdrivers.
  • Small, flat-bladed screwdriver or a flat-bladed alignment tool.
Parts required
The replacement part number will vary depending on the primary memory board that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP
Part Number
Requires Return
256MB, 533 MHz, 240-pin, PC4200, DDR2 SDRAM SO-DIMM
373119-001 (Original)
Yes
512MB, 533 MHz, 240-pin, PC4200, DDR2 SDRAM SO-DIMM
373120-001 (Original)
Yes
1.0GB, 533 MHz, 240-pin, PC4200, DDR2 SDRAM SO-DIMM
373121-001 (Original)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the primary memory board, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select primary memory board from the menu on the upper left hand side of the screen.
Click here to view the primary memory board removal video (right-click on the link to open in a new window/tab).
Primary memory board removal
  2. Push both arms outward simultaneously to release the primary memory board to the spring tension position.
    When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  3. Grasp the primary memory board by the edges and pull gently to remove it.
  4. Place the primary memory board in a static dissipative bag.
Primary memory board replacement
  1. Remove the primary memory board from the static dissipative bag.
  2. Locate the alignment slot and align it to the empty board receptacle.
  3. Grasp the primary memory board by the edges and push gently to replace it.
  4. Press the primary memory board down to latch the arms.
