HP Compaq nc6220 Notebook PC - Removing and Replacing Fan
This document is provided to assist in removing and replacing the Fan for the HP Compaq nc6220 Notebook PC.
Tools required
Small, Phillips-head (P0) screwdriver
Parts required
The replacement part number will vary depending on the Fan that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP.
Part Number
Requires Return
Fan
378233-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Fan, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Fan from the menu on the upper left hand side of the screen.
Click here to view the Fan removal video (right-click on the link to open in a new window/tab).
Fan removal
  2. Disconnect the fan cable from the system board.
  3. Loosen the two captive P0 Phillips-head screws that secure the fan to the base enclosure.
  4. Lift and remove the fan.
Fan replacement
  1. Place the fan into the base enclosure.
  2. Tighten the two captive P0 Phillips-head screws that secure the fan to the base enclosure.
  3. Reconnect the fan cable to the system board.
