HP LaserJet CP1215 and CP1217 Printers - 'Supply Memory Error' Message Displays on the Computer
This document is for the HP Color LaserJet CP1215 and HP Color LaserJet CP1217 printers.
A 'Supply Memory Error' message displays on the computer and indicates a specific print cartridge. The exact text of the message might vary:
  • 'Supply memory error in black'
  • 'Supply memory error in cyan'
  • 'Supply memory error in yellow'
  • 'Supply memory error in magenta'
Solution one: Make sure that the print cartridges are genuine HP print cartridges
Follow these steps to make sure that you have installed genuine HP print cartridges.
Step one: Make sure that the print cartridges are genuine HP print cartridges
Hewlett-Packard Company cannot recommend the use of non-HP print cartridges, either refilled, new, or remanufactured. Any damage caused by a non-HP print cartridge is not covered under the HP warranty and service agreements. See HP LaserJet Print Cartridges and Imaging Drums Limited Warranty Statement (c01848047) (in English).
  1. Open the front access door completely.
    Figure : Open the front access door completely
    Illustration: Open the front access door.
  2. Press the blue handle on the print cartridge drawer to release it, and then pull the drawer out completely.
    Figure : Pull out the print cartridge drawer
    Illustration: Pull out the print cartridge drawer.
  3. Grasp the center of one of the print cartridges, and then pull it straight up to remove it.
    Figure : Example of removing a print cartridge
    Illustration: Remove the print cartridge.
    To prevent damage to a print cartridge, do not expose it to light for more than a few minutes.
    Do not touch the green roller (imaging drum) on the bottom of the print cartridge. Fingerprints on the imaging drum can cause print-quality problems.
    Figure : Do not touch the imaging drum
    Illustration: Do not touch the imaging drum.
  4. Check the print cartridge to see if it has HP on it. Genuine HP print cartridges are always printed with HP, Hewlett-Packard, or the HP logo ().
    • If the print cartridges are genuine HP print cartridges, reinsert the print cartridge into the correct slot, and then continue to the next step.
    • If the print cartridge is not a genuine HP print cartridge, replace it with a genuine HP print cartridge.
  5. Hold the print cartridge so that the imaging drum faces the bottom of the print cartridge drawer, and then insert the print cartridge into the correct slot.
    Figure : Example of inserting the print cartridge
    Illustration: Insert the print cartridge into the correct slot.
  6. Repeat steps 3 to 5 for the other print cartridges.
  7. When you are sure that you have genuine HP print cartridges installed, close the print cartridge drawer completely.
    Figure : Close the print cartridge drawer completely
    Illustration: Close the print cartridge drawer.
  8. Close the front access door completely.
    Figure : Close the front access door completely
    Illustration: Close the front access door.
Step two: Turn the printer off and on
Turn the printer off and then on again.
  • If these steps resolved the issue, you do not need to continue troubleshooting.
  • If the issue persists, see the next solution.
Solution two: Clean the metal contacts on the print cartridges
The error message is sometimes caused by dirty metal contacts on the print cartridges. Follow these steps to clean the contacts.
  3. Remove one of the print cartridges.
  4. Use a lint-free cloth to wipe the E-label contact on top of the print cartridge to the left.
    Figure : Example of an E-label on the print cartridge
    Photograph: Example of an E-label on a print cartridge.
  5. Using the lint-free cloth, wipe the metal contacts on the end of the print cartridge.
  6. Reinstall the print cartridge into its slot.
  7. Repeat steps 3 to 6 for the other print cartridges.
  8. Close the print cartridge drawer completely.
  9. Close the front access door completely.
Solution three: Insert the problem print cartridge into a different slot
Follow these steps to determine if the print cartridge or the slot it sits in is causing the error.
  1. Open the print cartridge door completely.
  3. Remove one of the nonproblem print cartridges from its slot.
  4. Install the problem print cartridge into the empty slot.
  5. Install the other print cartridge into the slot of the problem print cartridge.
  6. Close the print cartridge drawer completely.
  7. Close the front access door completely.
  • If the error message persists, replace the problem cartridge.
  • If the error message is gone, contact HP to troubleshoot a faulty slot.
