    Fix HP Printer issue on macOS
HP 2310t Touchscreen LCD Monitors - Setting Up Your Monitor
This document describes steps to set up the HP 2310t Touchscreen LCD monitors.
Figure : HP 2209t monitor
2310 monitor
Rear panel components
The monitor connections are on the back of the monitor.
Figure : Back connections
Back connections
Component
Function
1
Security slot
Connects the security cable to the monitor to protect from theft.
2
AC power connector
Connects the AC power cord to the monitor.
3
USB upstream connector
Connects the monitor USB cable to a host computer for touch screen support.
4
DVI-D connector
Connects the DVI-D cable to the monitor.
5
Audio connector
Connects the audio cable to the monitor.
6
VGA connector
Connects the VGA cable to the monitor.
Step 1: Attaching the base
Use the following instructions to attach the base to the monitor:
The screen is fragile. Avoid touching or applying pressure to the LCD screen; doing so can cause damage.
  1. Place the monitor screen down on a flat, soft, protected surface.
  2. Align the monitor neck with the base.
  3. Secure the base to the monitor with the locking screw, making sure that the base is securely attached.
    Figure : Attaching the base
    Attaching the base
  4. To adjust the monitor, face the front of the monitor and hold the base with one hand.
  5. Adjust the tilt by moving the monitor top edge toward or away from you, without touching the screen. You can adjust the display's viewing angle from -5° to 20°.
Step 2: Connecting the monitor to the computer
  warning:
To reduce the risk of electric shock or damage to your equipment:
  • Do not disable the power cord grounding plug. The grounding plug is an important safety feature. Plug the power cord into a grounded electrical outlet.
  • Be sure the grounded power outlet you plug the power cord into is easily accessible to the operator and located as close to the equipment as possible. Route the power code to prevent objects being placed on it or someone walking on it.
  • Do not place anything on power cords or cables. Arrange them so that no one accidentally steps on or trips over them. Do not pull on a cord or cable.
  1. Turn off the computer.
  2. Connect one end of the power cord into the AC power connector on the back of the display, and the other end to an electrical outlet.
      Figure : Connecting the monitor to the computer
      Audio connections.
    1. Security lock slot
    2. Power cord
    3. Audio cable
    4. VGA cable
    5. USB cable
    6. DVI-D cable
  3. Connect one end of the audio cable to the audio-in connector on the back of the display, and the other end of the cable to the audio-out jack on the computer.
  4. Connect the video signal cable.
      Figure : Video connectors
      Video connectors
    1. VGA (D-sub 15 pin)
    2. DVI (24-pin)
    • For analog operation, use the VGA cable. Connect one end of the 15-pin VGA signal cable to the VGA connector on the back of the monitor, and connect the other end to the computer VGA port.
    • For digital operation, use the DVI-D cable. Connect one end of the 24-pin DVI cable to the back of the monitor and connect the other end to the computer DVI port.
  5. Connect one end of the USB cable to the USB connector on the display, and the other end of the USB cable to the computer.
    The USB cable is required for touch screen operation.
  6. Turn on your monitor and computer.
Step 3: Selecting the video input source
You can attach a VGA cable or a DVI-D cable, or both to the monitor. To use DVI, your computer must have a DVI-compliant graphics card. To change the input selection, use the Input option in the OSD menu.
  1. Press the Menu button on the front of the monitor until the Other menu displays.
  2. Select Input, and use the Left or Right arrow buttons on the monitor to choose Analog (D-sub) or Digital (DVI-D).
  3. When finished, press AUTO to exit from the OSD screen.
Step 4: Installing drivers
Install the monitor-driver INF and ICM files from the CD, or download them from the Internet as follows:
Installing the Touch Driver (for Windows XP only)
The touch driver is needed only for systems that use the Microsoft Windows XP operating system. You do not need to install the touch driver if your system has Windows Vista or Windows 7.
To install the touch driver:
  1. Insert the CD in the computer CD-ROM drive.
    The CD menu displays.
  2. Click Install Touch Driver for Microsoft Windows XP from the CD menu.
    The Touch Driver Setup Wizard displays.
    Touch drivers are not required for systems running Microsoft Windows Vista or Windows 7 operating systems.
  3. Follow the on-screen instructions in the wizard to install the driver.
Installing drivers from the CD
To install the monitor driver from the CD:
  1. Insert the CD in your computer CD drive.
    The CD menu appears.
  2. Select the language.
  3. Click Install Monitor Driver Software.
  4. Follow the onscreen instructions.
  5. Restart the computer.
  6. Check that the proper resolutions and refresh rates appear in the Display Properties window in the Control Panel.
Installing drivers from the Web
To download the latest version of drivers and software files from the HP Support Web site:
  1. Select your country/region.
  2. Select Download Drivers and Software.
  3. Enter the model number of your monitor: w1858 or w2338h.
    The software downloads information for your monitor.
  4. Ensure your system meets the requirements given.
  5. Download and install the driver and software files by following the steps on the screen.
Tips and recommendations
  • Unplug your monitor from the wall outlet before cleaning. Do not use liquid cleaners or aerosol cleaners. Use a damp cloth for cleaning. If the screen requires additional cleaning, use an antistatic screen cleaner.
  • Do not open your monitor or attempt to service this product yourself. Adjust only those controls that are covered in the operating instructions. If your monitor is not operating properly, or has been dropped or damaged, contact your HP authorized dealer, reseller, or service provider.
  • Use only a power source and connection appropriate for this monitor, as indicated on the label/back plate of the monitor.
  • Never disconnect the monitor by pulling the cord. Unplug the power cord from the power outlet by grasping the plug firmly.
  • Turn your monitor off when not in use. You can substantially increase the life expectancy of your monitor by using a screen saver program and turning off the monitor when not in use.
  • When removing the monitor base, place the monitor face down on a soft flat area to prevent it from getting scratched, defaced, or broken.
  • Burn-in image damage might occur on monitors that display the same static image on screen for a prolonged period of time. To avoid burn-in image damage on your monitor screen, always activate a screen saver application or turn off the monitor when it is not in use for a prolonged period of time.
