When you use the automatic document feeder (ADF) to copy, scan, or fax a document, the error message 'Original Jam: Clear jam, and then press OK' displays on the product control panel.
- ${title}
- ${title}
- ${title}
- ${title}
An 'Original Jam: Clear jam, and then press OK' Message Displays for HP Officejet 7200, 7300, and 7400 All-in-One Printer Series
Issue
![]() If you are looking for information on preventing a paper jam from recurring, you can skip to the prevention and cause sections in this document.
Video of clearing an ADF paper jam
The following video demonstrates steps to troubleshoot and to maintain the automatic document feeder (ADF). The product shown in this video might not look exactly like your product, but the steps are the same.
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube.
Solution one: Clear the paper jam from the ADF
Follow these steps in the order presented to clear a paper jam from the ADF.
Step one: Remove any loose paper
Remove any loose paper from the ADF input and output trays.
caution:Do not remove jammed paper at this stage.
Step two: Check the rollers in the automatic document feeder (ADF)
Press the Power button (
) to turn off the product.
Disconnect the power cord from the rear of the product.
Remove the ADF document feeder tray, and then lift the top cover of the ADF.Figure : Open the ADF cover
Remove the ADF cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the ADF cleanout part, and then set it aside.Figure : Remove the ADF cleanout part
Check for jammed paper where the paper enters the ADF cleanout.Figure : Check the ADF cleanout
Gently pull the paper out of the ADF cleanout without tearing the paper.
If any torn pieces of paper remain inside the product, more jams are likely to occur.Figure : Pull the paper from the ADF cleanout
Step three: Reinstall the ADF cleanout part
Gently slide the ADF cleanout part back into its slot until the tabs click into place.Figure : Reinstall the ADF cleanout part
Make sure that the ADF cleanout tabs snap into place. If the ADF cleanout part is loose or incorrectly installed, more paper jams are likely to occur.Figure : Installed ADF cleanout partnote:
If the ADF cleanout part is positioned correctly, the paper travels downward. If the ADF cleanout part is not positioned correctly, the paper travels out of the rear of the mechanism.Figure : Paper traveling out the rear of the mechanismFigure : Correctly positioned ADF cleanout partFigure : Incorrectly positioned ADF cleanout part -
Replace the ADF input tray.
Close the ADF cover.
Reconnect the power cord to the rear of the product.
) to turn on the product.
Step four: Clear the jam from the ADF paper path
Sometimes paper can jam under the edge of the document lid where the ADF feeds paper. Follow these steps in the order presented to clear a paper jam in the paper path.
Lift the document lid.Figure : Lift the document lid
Check for jammed or stuck paper under the edge of document lid where the ADF feeds paper through.Figure : Check under the edge of the lid
Gently remove any paper from under the document lid. If the paper does not come out with gentle pulling, follow these steps:
Close the document lid.
Open the ADF, and then use both hands to gently loosen the paper.
When the paper is free, gently pull it out.
Close the ADF.
Replace the document feeder tray.
Load plain white paper in the input tray.Figure : Load paper in the input tray
Reload the original document print side up in the document feeder tray.Figure : Reload the original document
Press OK to continue the current task.
If the product does not continue the task, start the task again.
If these steps resolved the issue, you do not need to continue troubleshooting.
If the issue persists, continue to the next solution.
Solution two: Clean the ADF pick rollers
Follow these steps in the order presented to clean the ADF pick rollers in your product.
Right click this link, Paper feed issues with the automatic document feeder, (c00222165) (in English), and then select Open in New Window.
Follow each of the steps as presented in the document.
When you complete the steps in the document, load plain white paper in the input tray.Figure : Load paper in the input tray
Solution three: Reset the product
Follow these steps to reset the product.
Step one: Perform a power reset
With the product turned on, disconnect the power cord from the rear of the product.
Unplug the power cord from the wall outlet.
Wait at least 15 seconds.
Plug the power cord back into the wall outlet.
If the product does not turn on by itself, press the Power button (
Step two: Make a copy using the ADF
Load one sheet from the original document print side up in the ADF input tray.Figure : Load a sheet from the original document
Press Start Copy Black or Start Copy Color. The product prints a copy of the page.
Solution four: Service the product
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
Preventing paper jams
Before loading paper in the input tray, hold the stack of paper, and then tap the bottom edge on a flat surface so that the stack is even on all sides.
Make sure that the length and width adjusters on the input tray are correctly positioned, and then push the stack of paper forward until it stops in the tray.
Do not force the paper to move too far forward in the tray. -
Do not overload the input tray with paper.
Only add paper to the input tray when the product is not printing.
Make sure that the product supports the paper type. See the documentation that came with the HP product for more information.
Do not print on paper with paper clips or staples attached.
Do not use paper that is bent, torn, dusty, damp, wrinkled, or curled, or paper that does not lie flat.
Use only one type of paper at a time. Do not mix different types, weights, or sizes of paper.
Do not use paper that is too thin, too thick, or too glossy for the product.
To help prevent ADF jams, make sure that the parts of the ADF are clean and free of dust or sticky material. This applies to the input and output trays, ADF scanner glass strip, cork pad, and pickup rollers.
Cause
Paper loaded incorrectly in the paper tray.
Damaged or dirty paper rollers.
Torn, wrinkled, or damp paper loaded in the paper tray.
Paper was added to a stack already in the tray while the HP product was printing.
The tray contains more than one type of paper.
The paper is jammed inside the HP product where you cannot see it.
An obstruction is blocking the paper path.
Torn pieces of paper from a previous jam are stuck in the product.
The tray is too full.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
