HP and Compaq PCs - Recovery Disc Creation Error Codes (Windows Vista)
This document pertains to HP and Compaq Desktop PCs with Windows Vista.
The explanations provided by this document will help to identify the reason or the source of the errors that may appear when using Recovery Manager to create recovery discs.
This section is provided for background information only.
Codes
The following codes are used by the Recovery Manager when it encounters an issue while creating recovery discs.
Error Code
0
Library writing error
2
Erasing operation could not be completed. RW media could not be formatted.
5
Undefined error.
6
User input parameter is not valid.
7
Invalid state. The ODD media state is unknown or unexpected.
8
Memory allocation failed.
9
System call failed. System call to ODD returned an error.
10
SCSI transport internal error.
11
SCSI device busy.
12
SCSI CDB delivery failed.
13
SCSI device of this type is not supported.
14
Invalid function calls response. Function call to ODD returned an error.
Exception was not allocated.
16
Access to feature denied.
17
User input caused exception.
20
Iso Image creation error.
