HP PCs - Is the Windows Version on My Computer 32-bit or 64-bit?
This document pertains to HP and Compaq computers with Windows 10, 8, 7, Vista, and XP.
Some software and drivers install only on 32-bit types of Windows. Some work only in 64-bit Windows. To download software and drivers from HP software download sites, you are required to select a 32-bit or 64-bit version of Windows.
To find which type of Windows you have, use one of the sections below:
If an HP software download page does not list 32-bit or 64-bit, the system type is 32-bit.
Find 32-bit or 64-bit system type and Windows version in Windows 10
Determine which version of Windows 10 you are using, and if it is 32-bit or 64-bit.
  1. In the Windows search bar, type About your PC.
  2. Click About your PC in the list of results.
  3. The Version and System type are shown on the About screen.
    About screen with Version and System type highlighted
Find 32-bit or 64-bit system type in Windows 8
Determine which version of Windows 8 you are using, and if it is 32-bit or 64-bit.
  1. At the Start screen, type File Explorer to open the Search charm, and then select File Explorer from the Search results list.
    Search field with File Explorer selected
    The Computer window opens.
  2. Select the Computer tab, and then click Properties.
    Properties
  3. Find "System Type" and note whether your operating system is 32-bit or 64-bit.
    System type showing 64-bit
Find 32-bit or 64-bit system type in Windows 7 and Vista
Determine which version of Windows 7 or Vista you are using, and if it is 32-bit or 64-bit.
  1. Click Start and right-click Computer.
  2. Select Properties.
     View Basic Information window with System Type highlighted
Find 32-bit or 64-bit system type in Windows XP
To find the Windows type, do the following:
  1. Click Start and right-click My Computer.
  3. From the General tab, look at the Windows XP version name listed under System. If the version name contains the text "x64 Edition", your computer has a 64-bit version of Windows XP. If "x64 Edition" is not shown, your computer has a 32-bit version of Windows XP.
    System Properties window with General tab selected and Windows Edition highlighted
Find 32-bit or 64-bit system type if your computer does not start
If your computer does not start, you can find the 32-bit or 64-bit system type that your computer originally came with from the product packaging. You can also find the system type on the Web from a product specification document. For HP and Compaq PCs, use the following steps to find your support specification on the Web.
  1. In the Search field at the top of this page, type your computer model number, a space, and the word "specification".
    For example, if you owned a Touch 600-1055 computer, you would type: 600-1055 specification
  2. Click the link on the search results page that matches the Product Specifications for your computer model.
    A product specification support document opens.
  3. Scroll down to the software section to find the version of operating system and the system type.
    The type should be listed with name of the operating system; for example: Windows Vista Home Premium (64-bit). If 32-bit or 64-bit is not listed next to the name of the operating system, the system type is 32-bit.
