HP LaserJet Pro M1130 and M1210 Multifunction Printer Series - Redistributing the Toner
Redistribute toner
When a small amount of toner remains in print cartridge, faded or light areas might appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner.
  1. Lift the scanner assembly, and open the print-cartridge door.
    Figure : Scanner and print-cartridge door
  2. Remove the print cartridge.
    Figure : Remove the print cartridge
  3. To redistribute the toner, gently rock the print cartridge from front to back.
    Figure : Rocking motion
    If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
  4. Install the print cartridge.
    Figure : Install the print cartridge
  5. Close the print-cartridge door and the scanner assembly.
If the print is still light, install a new print cartridge.
