HP LaserJet Pro M1130 and M1210 Multifunction Printer Series, HP LaserJet Pro M1217nfw Multifunction Printer Series, and HP HotSpot LaserJet Pro M1218nfs MFP Series - Printer Views
Front view
M1130 Series
    Figure : Front view of product
  1. Scanner lid
  2. Scanner assembly
  3. Output bin with extension for long paper
  4. Print-cartridge door lift-tab
  5. Input tray
  6. Short media extender tool
  7. Power button
  8. Control panel
M1210 Series
  1. Document feeder
  2. Document feeder output bin
  3. Scanner lid
  4. Scanner assembly
  5. Output bin with extension for long paper
  6. Print-cartridge door lift-tab
  7. Input tray
  8. Short media extender tool
  9. Power button
  10. Control panel
Back view
M1130 Series
    Figure : Back view of product
  1. Slot for a cable-type security lock
  2. Hi-Speed USB 2.0 port
  3. Power connection
M1210 Series
  2. RJ-45 network port
  3. Hi-Speed USB 2.0 port
  4. RJ-11 fax ports
  5. Power connection
Serial number and model number location
The serial number and product model number label is at the back of the product.
Figure : Serial number and model number location
Control-panel layout
M1130 Series
    Figure : Control-panel components
  1. Display – Shows number of copies.
  2. - Up/Down Arrow buttons – Used to increase/decrease the number of copies to be made, and to adjust the light/dark and reduce/enlarge settings.
  3. - Reduce/Enlarge Indicator LED (Active when lit) - Use the arrow keys to adjust the reduce/enlarge setting for the next copy job.
  4. - Light/Dark Indicator LED (Active when lit) - Use the arrow keys to adjust the light/dark setting for the next copy job.
  5. - Number of Copies Indicator LED (Active when lit) - Use the arrow keys to adjust the number of copies for the next copy job.
  6. - Copy Settings Toggle button - Used to switch between the 3 copy settings available.
  7. - Copy button – Press to make a copy with current settings.
  8. - Cancel button – Used to cancel a print job, scan, or copy job.
  9. - Toner LED – Blinks when there is an issue with the toner (problem with cartridge, missing cartridge, etc).
  10. - Attention LED – Blinking when there is an issue.
  11. - Power LED – Solid when in a ready state, and blinking when busy.
M1210 Series
  1. - Toner LED – Blinks when there is an issue with the toner (problem with cartridge, missing cartridge, etc.), and is usually accompanied by a message on the display.
  2. - Attention LED – Blinking when there is an issue (usually accompanied by a message on the display (paper jam, door open, etc.).
  3. - Power LED – Solid when in a ready state, and blinking when busy.
  4. 2-line Display – Used to display messages, menu navigation, printer status, time, etc.
  5. - Copy settings button – Press button to scroll through available copy settings (reduce/enlarge, # of copies, light/dark, etc.).
  6. - Setup button – Brings up the menu on the screen.
  7. - Left/Right Arrow buttons – Used to navigate through the menus and options.
  8. - OK button – Used to confirm a change in a menu.
  9. - Cancel button – Used to cancel a print, scan, or copy job, and to back out of menus to the home screen.
  10. - Copy button – Press to make a copy with current settings.
  11. - Back button – Used to back out of menus to the home screen.
  12. - Send Fax button – Press to initiate a fax.
  13. - Redial button – Used to retry a fax, or redial the last fax recipient.
  14. - Light/Dark Copy Setting shortcut – Used to go to the copy settings – light/dark screen.
  15. Number Pad – Used to enter phone numbers for faxing, or to enter the number of copies manually (when in the copy settings, # of copies screen).
