HP iPAQ Data Messenger - Garbage Text Appears with Swedish Language Settings
Issue
When sending a text message (SMS) from the HP iPAQ Data Messenger series with the Swedish language settings, the message appears to be a garbage message at the receiving end.
Example: Hw§ΠO#Rræ/¥ΘCutYüΞ¥Ça=ò àWOi:hmùQQeΔ1Æì5A´wY§Π¥Xo1^vgih5ä´?Aawüm/¥SgPüÑìΩqqsΘÅ´?Ag3æΛ&¥EaqÄ%$@@@@@@@@@@@@@
Solution
To fix this follow the steps given below.
Launch Inbox and click "Menu". Click "Tools" and choose "Options". Then Click on "Text/MMS". You will see this setting "Use unicode when necessary" check the box. If its checked then uncheck and test the unit. If the issue still persists after performing the above steps elevate a case to competency center.
