    Fix Windows 10 Update Issues
A 'Carriage Jam-Open print carriage access door. Clear Jam, and then press OK' Message Displays for HP Officejet 4500 (G510) Series and 4500 (K710) Series All-in-One Printers
Issue
A 'Carriage Jam-Open print carriage access door. Clear Jam, and then press OK' message displays on the product control panel. The carriage assembly, which holds the cartridges, stalls on one side or in the center of the product.
You might also experience the following symptoms:
  • The product won't print.
  • Printing stops unexpectedly.
  • A paper jam might have occurred previously.
  • The product makes loud grinding noises.
How to use the solutions in this document
To resolve the issue, try each solution in this document in the order presented.
IMPORTANT: Each time you try a solution, try to print a self-test report to determine if the hardware is functioning correctly. To print a self-test report, use the steps in the following table.
How to print a self-test report
  1. Load plain, white paper into the input tray.
  2. Press the Setup button () on the product control panel.
  3. Press the Right Arrow button () to select Print Report, and then press OK.
  4. Press the Right Arrow button () to select Self-test, and then press OK.
    A self-test report prints.
Refer back to the steps in this table after attempting each solution.
Video of clearing a carriage jam
The following video demonstrates how to clear a carriage jam.
This video shows the HP Officejet 4500 All-in-One Printer series (G510), but the steps are the same for your printer.
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube.
Solution one: Turn the All-in-One off and then on again
  1. Press the Power button () to turn off the product.
  2. Wait 60 seconds.
  3. Press the Power button () to turn on the product.
    The product might go through a warm-up period. The product lights might flash and the carriage might move. Wait until the warm-up period finishes before proceeding.
  4. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue, and the test page prints, there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again.
  • If the issue persists, continue with the next solution.
  • If the test page does not print, continue with the next solution.
Solution two: Clear any jammed paper
Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper.
The Automatic Document Feeder (ADF) is not included with all Officejet 4500 All-in-One products.
Step one: Remove any loose paper
Remove any loose sheets of paper from the input tray and the output tray.
Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism.
Step two: Clear the jam from the back of the All-in-One
  2. Disconnect the USB cable from the back of the product.
  3. Disconnect the power cord from the back of the product.
  4. On the back of the product, press in the tab on the left side of the rear access door to release the door. Pull the door away from the product to remove it.
    Figure : Remove the rear access door
    Illustration of removing the rear access door
  5. Gently pull the paper out of the rollers.
    If the paper tears when removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. Reattach the rear access door. Gently push the door forward until it snaps into place.
Step three: Clear the paper jam from the front of the All-in-One
If you cannot remove the paper jam from the back of the product, follow these steps to remove the paper jam from the front.
  1. Open the front access door. The carriage might try to move into the access area. If so, allow it to move to that position.
    Figure : Open the front access door
    Illustration of opening the front access door
  2. Gently pull the paper out of the rollers.
    Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism.
  3. Close the front access door.
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button () to turn on the product.
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Solution three: Make sure that the carriage moves freely
Use the following steps to make sure that the carriage moves freely.
  1. Press the Power button () to turn on the product.
  2. Open the front access door. The carriage might try to move into the access area. If so, allow it to move to that position.
  3. Without turning off the product, disconnect the power cord from the back of the product.
    You must disconnect the power cord to move parts by hand without the risk of an electrical shock.
  4. Disconnect the power cord from the wall outlet.
  5. Look inside the product to see where the carriage is stuck, and then check for any torn paper or objects that might be restricting the carriage.
    You might need a flashlight to illuminate areas for proper viewing.
  6. Reach inside the product through the front access door, and then manually move the carriage.
    • If the carriage is stuck on the right side of the product, move the carriage to the left side of the product.
    • If the carriage is stuck on the left side of the product, move the carriage to the right side of the product.
    • If the carriage is stuck in the middle of the product, move the carriage to the right side of the product.
  7. Remove any loose paper or obstructions found.
  8. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right.
  9. Close the front access door.
  10. Reconnect the power cord to the back of the product.
  11. Reconnect the power cord to the wall outlet.
  12. Press the Power button () to turn on the product.
  13. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Solution four: Remove and reinstall the cartridges
Improper placement or installation of the cartridges can cause the product to indicate a carriage jam error. Follow these steps to remove and then reinstall the cartridges.
Step one: Remove the cartridges
  2. Open the front access door. The carriage might try to move into the access area. Wait until the carriage is idle and silent before continuing.
  3. Push down on the top of the cartridge to release it, and then pull it toward you to remove it from its slot.
    Figure : Remove the cartridge
    Illustration of removing the cartridge
    Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
    Figure : Do not touch the contacts or ink nozzles
    Illustration of how not to touch the contacts or ink nozzles
  4. Repeat these steps for the other cartridge.
  5. Check for obstructions under and around the carriage. Remove any obstructions.
Step two: Reinstall the cartridges
  1. Slide the cartridge forward into the empty slot, and then gently push on the upper part of the cartridge until it clicks into place.
    Figure : Reinstall the cartridge
    Illustration of reinstalling the cartridge
    • If you are installing the tri-color cartridge, slide it into the left slot.
    • If you are installing a black or photo cartridge, slide it into the right slot.
  2. Repeat these steps for the other cartridge.
Solution five: Plug the product directly into a wall outlet
Plug the product directly into a wall outlet to make sure the power source is functioning correctly.
  1. Disconnect the power cord from the back of the product.
  2. Disconnect the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
  3. Reconnect the power cord to the back of the product.
  4. Press the Power button () to turn on the product.
  5. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
    If the product prints when plugged directly into a wall outlet, the power strip or surge suppressor might not be allowing enough voltage to reach the product.
Solution six: Perform a partial reset
Use the following steps to reset the product.
  2. Disconnect the power cord from the back of the product.
  3. Wait 20 seconds.
  4. Press and hold down # and 3 on the product control panel.
  5. While holding down these buttons, reconnect the power cord to the back of the product.
  6. After the product turns on, release both buttons. The product resets to the factory defaults.
  7. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If the test page prints successfully, but you experience a different issue with your printer, go to HP Product Support Home Page, and then search for another document that relates to the issue you are experiencing.
    If the page displays in the wrong region or language, click the Region - Language link in the upper right corner of your browser. Then you can select the correct region and language.
  • If the product does not print a test page, there is an issue with the product hardware. Continue to the next solution.
Solution seven: Service the All-in-One
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
