HP TouchSmart 600 Series Desktop PCs - Using the Ambient Light
This document pertains to HP 600 series TouchSmart computers.
Some HP TouchSmart PCs come with an ambient light feature. If your TouchSmart computer comes with the ambient light feature, you can use it to cast a glow from the base of the computer. In select models you can change the color of the light.
By default, the ambient light is turned off when you turn on the computer.
To control the light, press the ambient light button on the left side of the computer to turn the ambient light on.
Continue pressing the button to cycle through low intensity, medium intensity, high intensity, off, and on.
Figure : Ambient light button
The ambient light dims when the computer goes into sleep mode.
To change the color or intensity of ambient light (select models only):
  1. Tap Start , and type ambient light in the Search box. In the search results, tap HP Ambient Light.
    The HP Ambient Light screen displays.
    Figure : HP Ambient Light screen on the TouchSmart 600
  2. Tap the color you want.
  3. Change the intensity of light by tapping toward the top or toward the bottom of the color spectrum, or by pressing the ambient light button on the computer.
Country: Flag Bulgaria
