HP 50g Graphing Calculator - Hypothesis tests - Real Estate
The STAT menu
The Statistics menu is accessed from the ORANGE shifted function of the key by pressing . When pressed, a CHOOSE box is displayed with a number of problem areas within statistics where the HP 50g can be applied.
Figure : Displays a CHOOSE box
The first choice deals with calculating many values related to the statistics of a single variable, such as the average, standard deviation and others. The second choice deals with placing data within bins or classes and is useful when dealing with frequency distributions or when there is a need to summarize data within a histogram. The third choice, Fit Data.. is what we will use to compute trend lines. The fourth choice allows for the computation of summary statistics from a data set, such as the sum of all X values, the sum of all the Y values squared, and others. The fifth choice allows for the evaluation of many different hypothesis tests and the sixth choice allows for the construction of confidence intervals around a sample mean.
To evaluate a hypothesis test, press to immediately choose the Hypoth. tests function. to immediately choose the Conf. interval function.
Hypothesis tests
The next screen displays the choices for the different types of hypothesis tests the HP 50g can evaluate. A hypothesis test makes a statement about a population statistic, usually the mean, and acceptance of the hypothesis is determined by taking a sample from the population.
Figure : Displays various hypothesis tests
The first choice is for a hypothesis test for the population mean with either a known population variance or for a large sample (usually more than 30) with an unknown population variance.
The second choice is for a hypothesis test for the difference between two population means with either a known population variance or for a large sample (usually over 30) if the population variance is unknown.
The third and fourth choices are similar to the first two choices, except that they are applied to proportions.
The first four choices use the normal probability distribution and calculate a critical Z value.
The fifth and sixth choices are similar to the first two choices, except they deal specifically with situations where small sample sizes are present and the population variances and standard deviations are unknown. These use the Student’s t probability distribution.
When chosen, each hypothesis test displays an input form where the necessary information to evaluate the hypothesis test is entered, including the proposed population statistic value, sample averages, population or sample standard deviations, size of the sample(s), and the level of significance desired for the evaluation of the hypothesis test.
Practice evaluating hypothesis tests – real estate
Example 1
Jack believes that the average price for all homes in his area is $217,000. A sample of 100 sales prices of homes within his area was taken. The sample average sales price was $215,000 with a standard deviation of $24,000. Evaluate the null hypothesis at a 5% significance level. Should Jack’s hypothesis be accepted?
Solution
Since the sample size is over 30, we can use the first hypothesis test even though the population variance and population standard deviation are not known.
Figure : Entering the values
(this is to test whether the average is equal to or not equal to the null value of $217,000).
Figure : Displays the values
Figure : Displays the graph
Answer
The critical Z values indicate the boundaries beyond which we would not be able to accept the null hypothesis if the calculated or test Z value is above or below those critical values. The critical Z values for this hypothesis test are –1.96 and 1.96. The test Z or calculated Z value is –0.8333, which falls within the critical Z value boundaries. We therefore would fail to reject the null hypothesis. Jack’s estimate of the average price of all houses in his area would be accepted.
Example 2
Two realtors were being compared by their office manager. A sample of 15 houses sold by Realtor 1 generated an average price of $186,200 and a sample standard deviation of $25,480. A sample of 12 houses sold by Realtor 2 generated an average price of $193,200 and a sample standard deviation of $34,320. At the 5% significance level, is the average sales amount different between the two realtors significant? The null hypothesis would be that the difference between the two realtor’s average sales prices would be zero.
Solution
This will be a hypothesis test for the difference between the two population means, both of which are estimated by the sample means of the two realtors.
This will be a hypothesis test from choice 6 of the CHOOSE box, because we will be comparing the difference between 2 population means with unknown population variances. It will use the Student’s t statistic. Note that since we have the samples’ standard deviations rather than the populations’ standard deviations, the Checkbox for “pooled” will need to be selected. If we had the populations’ standard deviations, this would not be necessary.
(this is to test whether the two averages are equal to each other – in other words, is the difference between the averages zero or not).
Figure : Displays the options
Answer
The critical Z values indicate the boundaries beyond which we would not be able to accept the null hypothesis if the calculated or test Z value is above or below those critical values. The critical Z values for this hypothesis test are –2.06 and 2.06. The test Z or calculated Z value is –0.9413, which falls within the critical Z value boundaries. We therefore would fail to reject the null hypothesis. There is no reason to believe there is any difference between the two realtors.
