HP Pro 3010 Microtower Business PC Specifications
Product description
HP Pro 3010 Microtower business PC is powerful enough to handle everyday business needs now, with enough flexibility built-in which allows to keep an eye towards the future.
Product features
Feature
  • Intel G43 Express
  • Intel I/O Controller Hub 10 (ICH10)
Processor and Speed
Intel Celeron Processors:
  • Intel Celeron 440 Processor (2.0-GHz, 512KB L2 cache, 800 MHz FSB)
  • Intel Celeron 450 Processor (2.2-GHz, 512KB L2 cache, 800 MHz FSB)
Intel Celeron Dual-Core Processors:
  • Intel Celeron E1500 Processor (2.2-GHz, 512K L2 cache, 800 MHz FSB)
  • Intel Celeron E3200 Processor (2.4-GHz, 1MB L2 cache, 800 MHz FSB
  • Intel Celeron E3300 Processor (2.5-GHz, 1MB L2 cache, 800 MHz FSB)
Intel Pentium Dual-Core Processors:
  • Intel Pentium E5300 Processor (2.6-GHz, 2MB L2 cache, 800 MHz FSB)
  • Intel Pentium E5400 Processor (2.7-GHz, 2MB L2 cache, 800 MHz FSB)
  • Intel Pentium E6300 Processor (2.8-GHz, 2MB L2 cache, 1066 MHz FSB)
  • Intel Pentium E6500 Processor (2.93-GHz, 2MB L2 cache, 1066 MHz FSB)
Intel Core 2 Duo Processors:
  • Intel Core 2 Duo E7500 Processor (2.93-GHz, 3MB L2 cache, 1066 MHz FSB)
  • Intel Core 2 Duo E7600 Processor (3.06-GHz, 3MB L2 cache, 1066 MHz FSB)
  • Intel Core 2 Duo E8400 Processor (3.0-GHz, 6MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Duo E8500 Processor (3.16-GHz, 6MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Duo E8600 Processor (3.33-GHz, 6MB L2 cache, 1333 MHz FSB)
AMD Phenom II X2 Dual-Core Processors:
  • Intel Core 2 Quad Q8300 Processor (2.5-GHz, 4MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Quad Q8400 Processor (2.66-GHz, 4MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Quad Q9400 Processor (2.66-GHz, 6MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Quad Q9550 Processor (2.83-GHz, 12MB L2 cache, 1333 MHz FSB)
  • Intel Core 2 Quad Q9650 Processor (3.0-GHz, 12MB L2 cache, 1333 MHz FSB)
Intel processor numbers are not a measure of performance. Processor numbers differentiate features within each processor family, not across different processor families.
System Memory
  • 1GB DDR3 Synch DRAM PC3-10600 (1066/1333 MHz) Non-ECC (1 x 1GB)
  • 2GB DDR3 Synch DRAM PC3-10600 (1066/1333 MHz) Non-ECC (2 x 1GB)
  • 2GB DDR3 Synch DRAM PC3-10600 (1066/1333 MHz) Non-ECC (1 x 2GB)
  • 3GB DDR3 Synch DRAM PC3-10600 (1066/1333 MHz) Non-ECC (3 x 1GB)
  • 3GB DDR3 Synch DRAM PC3-10600 (1066/1333 MHz) Non-ECC (1 x 1GB + 1 x 2GB)
  • 4GB DDR3 Synch DRAM PC3-10600 (1066/1333 MHz) Non-ECC (4 x 1GB)
  • 4-GB DDR3 Synch DRAM PC3-10600 (1066/1333 MHz) Non-ECC (2 x 2GB)
  • 8GB DDR3 Synch DRAM PC3-10600 (1066/1333 MHz) Non-ECC (4 x 2GB)
Memory runs at maximum system supported speed of 1066 MHz, or at 800 MHz when processor has 800 MHz FSB. For systems configured with more than 3GB of memory and a 32 bit operating system, all memory may not be available due to system resource requirements. Addressing memory above 4GB requires a 64 bit operating system.
Hard Drives
  • 160GB 7200 rpm Serial ATA 3.0Gb/s NCQ, SMART
  • 250GB 7200 rpm Serial ATA 3.0Gb/s NCQ, SMART
  • 320GB 7200 rpm Serial ATA 3.0Gb/s NCQ, SMART
  • 500GB 7200 rpm Serial ATA 3.0Gb/s NCQ, SMART
Storage
Optical Drives (Serial ATA):
  • SATA DVD-ROM Drive
  • SATA SuperMulti LightScribe DVD Writer
  • HP SATA Blu-ray Writer
Media Reader: HP 22-in-1 Media Card Reader
Keyboard/Mouse
Keyboard:
  • HP USB PS/2 Washable Keyboard
  • HP USB Standard Keyboard
  • HP USB Mini Keyboard
  • HP USB Smartcard Keyboard
Mouse:
  • USB 2-Button Optical Scroll Mouse
  • USB 2-Button Laser Mouse
Graphics
  • Intel Graphics Media Accelerator X4500HD
  • ATI Radeon HD 4350 (512MB) FH PCIe x16 Card (for MT only)
  • ATI Radeon HD 4550 (256MB) DH PCIe x16 Graphics Card
  • ATI Radeon HD 4650 1GB Dual Head PCIe x16 Card (FH for MT only)
  • NVidia GeForce G210 512MB ATX PCIe x16 (for MT only)
  • NVidia GeForce GT230 1.5GB PCIe x16 Card
  • DMS-59 To Dual DVI Y-Cable Adapter
Miscellaneous
  • HP Chassis Security Kit
  • Belkin USB to Serial Port Adapter
Power Supply
300 W PFC
Security
Communications
Features
Communication
  • Realtek 8111DL GbE Ethernet Controller
  • Intel Gigabit CT Desktop NIC
  • LSI PCIe x1 56K International SoftModem
  • HP Wireless 802.11 b/g/n PCIe x1 Card
Graphics
Audio
Features
Audio
  • Realtek ALC662 HD Audio compatible codec with two channel audio
  • 3D audio compliant with AC’97 rev. 2.3
Physical specifications
Features
Chassis Dimensions (H x W x D)
385 x 185 x 416 mm (15.14 x 7.27 x 16.36 in)
System Weight
7.58 kg (16.7 lb)
Temperature
Operating: 5° to 35°C (41° to 95°F)
Storage: 90% RH @ 60°C for 12 hours (Non-condensing)
Operating temperature is de-rated 1.0 deg C per 300 m (1000 ft) to 2286 m (7500 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 7.5 deg C/Hr. The upper limit may be limited by the type and number of options installed.
Humidity
Operating: 10% to 90% (non-condensing at ambient)
Storage: 90% relative humidity (Rh), 60°C for 12 hours, non-condensing
Altitude
Operating: 3048 m (10,000 ft)
Non-Operating: 9144 m (30,000 ft )
Software/OS
Feature
Operating System
  • Genuine Windows 7 Professional Edition 32
  • Microsoft Windows XP
  • Windows Vista
Warranty information
HP Services includes a one-year standard parts and labor warranty, pick-up or carry-in, and toll-free 7 x 24 hardware technical phone support. On-site service and warranty upgrades are also available.
