HP Color LaserJet CP2020 Printer Series - Set Control Panel Language to English
Issue
The printer displays the control panel in a foreigner language.
Solution
Restart the printer and ensure it is in Ready mode with Ready light on the printer control panel.
Then, to change the display language back to English, perform the following steps:
  1. Press the right arrow two times, press the OK button (it should be in the System Setup menu).
  2. Press the OK button again (it should be in Language).
  3. Press the right arrow until you see something that is English, press OK button.
    The menu is a continuous loop, so if the above is missed for the first time, the option will return.
