HP Compaq 8510w Mobile Workstation - Removing and Replacing the Bluetooth Module
This document is provided to assist in removing and replacing the Bluetooth module for the HP Compaq 8510w Mobile Workstation.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
P0 Phillips-head screwdriver
P1 Phillips-head screwdriver
Parts required
The replacement part number will vary depending on the Bluetooth module that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Bluetooth module - Bluetooth specification v2.0 compliant
398393-002 (Modified)
No
Embedded Bluetooth module - Does not include cable (For use in Japan and Asia Pacific regions)
450066-001 (Modified)
No
Cable kit - Includes cables for Bluetooth module, RJ-11 connector, microphone, and module module
452198-001 (Modified)
No
Summary of instructions
To view a video demonstrating the procedure for removing the Bluetooth module, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Services Media Library), then select Bluetooth module from the menu on the upper left hand side of the screen.
Click here to view the Bluetooth module removal video (Right-click on the link to open in a new window/tab).
  2. Grasp the Mylar tab and slide the Bluetooth module out of the slot in the Hard disk drive bay.
  3. Disconnect the Bluetooth module cable from the Bluetooth module.
  4. Place the Bluetooth module in a static dissipative bag.
Bluetooth module replacement
  1. Remove the Bluetooth module from the static dissipative bag.
  2. Reconnect the Bluetooth module cable to the Bluetooth module.
  3. Slide the Bluetooth module into the slot in the hard disk drive bay.
