    We are upgrading our website
HP Compaq nc4400 Notebook PC - Removing and Replacing the Fan
This document is provided to assist in removing and replacing the Fan for the HP Compaq nc4400 Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P0,P1) screwdrivers.
Small, flat-bladed screwdriver or a flat-bladed alignment tool.
Torx 8 (T8) screwdriver.
Parts required
The replacement part number will vary depending on the Fan that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Cooling fan
419127-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the Fan, click on the link below. Or use the product video listing on the (Click here to go to HP Service Media Library), then select Fan from the menu on the upper left hand side of the screen.
Click here to view the Fan removal video (right-click on the link to open in a new window/tab).
Fan removal
  2. Disconnect the fan cable from the system board.
  3. Remove the three T8-7 mm screws that secure the fan to the base enclosure.
  4. Lift and remove the fan.
Fan replacement
  1. Place the fan into the base enclosure.
  2. Replace the three T8-7 mm screws that secure the fan to the base enclosure.
  3. Reconnect the fan cable to the system board.
Parts return
