HP Scanjet Enterprise 7000n - Install the hardware integration pocket
Use the included hardware integration pocket (packaged with the output tray) with a separately-purchasable HP accessory such as a secure card reader to provide secure access to your product.
To install the hardware integration pocket, follow these steps.
  1. Open the hatch.
  2. Using a T-8 Torx screwdriver (not included), turn the hardware integration pocket panel retaining screw counterclockwise to loosen and remove the screw, rotate the panel up and toward you as shown, and then remove the panel.
    Figure : Location of the HIP pocket panel
  3. Gently pull the hardware integration pocket connector up and out of its recessed location.
    Figure : Location of the HIP connector
  4. Using a credit card, gently pry up one edge of the hardware integration pocket insert, and then remove the insert.
    Figure : Location of the HIP insert
  5. Carefully thread the hardware integration pocket connector through the opening in the left side of the pocket.
    Figure : HIP connector threaded
  6. Install the hardware integration pocket on the product as shown by rotating the pocket into place, and then secure the pocket with the screw you removed in Step 2.
    Figure : HIP attached to product
  7. Follow the installation instructions that came with the HP accessory, ensuring that you place the accessory cable such that you can fit the accessory on top of the hardware integration pocket.
    Figure : HIP attached to connector
