    Windows 11 Upgrade Guide
HP Compaq 6005 Pro Small Form Factor PC Product Specifications
HP Compaq 6005 Pro Small Form Factor PC.
Product features
Feature
AMD 785G chipset
Processors
AMD Sempron Processors with HyperTransport Technology:
  • AMD Sempron 140 Processor (2.7-GHz, 1MB L2 cache, HT bus 3.0)
AMD Athlon II Dual-Core Processors with HyperTransport Technology:
  • AMD Athlon II X2 215 Processor (2.7-GHz, 1MB L2 cache, HT bus 3.0)
  • AMD Athlon II X2 B22 Processor (2.8-GHz, 2MB L2 cache, HT bus 3.0)
  • AMD Athlon II X2 B24 Processor (3.0-GHz, 2MB L2 cache, HT bus 3.0)
AMD Phenom II Dual-Core Processors with HyperTransport Technology:
  • AMD Phenom II X2 B53 Processor (2.8-GHz, 1MB L2 cache, 7MB Total cache, HT bus 3.0)
  • AMD Phenom II X2 B55 Processor (3.0-GHz, 1MB L2 cache, 7MB Total cache, HT bus 3.0)
AMD Phenom II Triple-Core Processors with HyperTransport Technology:
  • AMD Phenom II X3 B73 Processor (2.8-GHz, 1.5MB L2 cache, 7.5MB Total cache, HT bus 3.0)
  • AMD Phenom II X3 B75 Processor (3.0-GHz, 1.5MB L2 cache, 7.5MB Total cache, HT bus 3.0)
AMD Phenom II Quad-Core Processors with HyperTransport Technology:
  • AMD Phenom II X4 B93 Processor (2.8-GHz, 2MB L2 cache, 8MB Total cache, HT bus 3.0)
  • AMD Phenom II X4 B95 Processor (3.0-GHz, 2MB L2 cache, 8MB Total cache, HT bus 3.0)
Memory
Supports un-buffered non-ECC DDR3 SDRAM
  • HP 4GB PC3-10600 (DDR3 1333 MHz) DIMM
  • HP 2GB PC3-10600 (DDR3 1333 MHz) DIMM
  • HP 1GB PC3-10600 (DDR3 1333 MHz) DIMM
Maximum Memory
Supports up to 16GB of un-buffered non-ECC DDR3 SDRAM.
Solid State Drive
64GB Solid State Drive
RapidDrive
RapidDrive is an optional new productivity solution available only on the HP Compaq 6005 Pro. It links the Solid State Drive (SSD) and Hard Drive together to form one virtual drive that combines the advantages of both technologies. Pre-installed applications reside on the SSD for reduced access time, yet the usual limitations of SSD storage are eliminated by linking it with a large hard drive.
Removable Storage
Pocket Media Drive:
  • 250GB Pocket Media Drive
Media Reader:
  • HP 22-in-1 Media Card Reader (USB connection on the system board)
  • HP 22-in-1 (with 1394) Media Card Reader (USB connection on the system board)
Optical drive
  • SATA DVD-ROM Drive
  • SATA SuperMulti LightScribe DVD Writer Drive
  • SATA Blu-ray Writer
Keyboard/Mouse
Keyboard:
  • HP PS/2 Standard Keyboard
  • HP USB Standard Keyboard
  • HP Smartcard Keyboard
Mouse:
  • USB 2-Button Laser Mouse
  • PS/2 2-Button Optical Scroll Mouse
  • USB 2-Button Optical Scroll Mouse
Power Supply
240 W BTX Active PFC
Hardware Specifications
Features
Chassis Dimensions (HxWxD)
100.3 x 337.8 x 378.5 mm (3.95 x 13.30 x 14.90 in)
Temperature
Operating: 10° to 35°C (50° to 95°F)*
Non-operating: -30° to 60°C (-22° to 140°F)
* Operating temperature is de-rated 1.0°C per 300 m (1000 ft) to 3000 m (10,000 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 10°C/Hr. The upper limit may be limited by the type and number of options installed.
Humidity
Operating: 10% to 90% (non-condensing at ambient)
Non-operating: 5% to 95% (non-condensing at ambient)
Altitude
Operating: 3048 m (10,000 ft)
Non-Operating: 9144 m (30,000 ft)
System weight
7.26 kg (16.0 lb)
Power
240 W BTX power supply - Active PFC
Security
  • TPM 1.2 Embedded Security Chip*
  • HP Desktop Security lock kit (lock and cable)
  • HP Chassis Security Kit
  • Security cable with Kensington lock
  • HP Solenoid Hood Lock and Sensor
  • Optional HP ProtectTools 5.0 security software suite
  • Optional LoJack Pro tracking and tracing subscription
  • Optional USB Port Disable at factory (user configurable via BIOS)
  • RAID 0,1 support
* TPM module disabled where use is restricted by law; for example, Russia.
Communications
Features
Communication
Wireless LAN: HP 802.11 b/g/n Wireless PCIe x1 card.
NICs: Broadcom NetXtreme Gigabit Ethernet Plus PCIe NIC.
Modem: LSI PCIe x1 56K International SoftModem.
Graphics
Multi head solutions:
  • ATI Radeon HD 4550 (256MB DH) PCIe x16 Card
  • ATI Radeon HD 4650 (1GB DH) PCIe x16 Graphics Card
  • HP DisplayPort to VGA Adapter
  • HP DisplayPort to DVI-D Adapter
  • NVIDIA Quadro NVS 290 (256MB DH) PCIe x1 Graphics Card
  • NVIDIA Quadro NVS 290 (256MB DH) PCIe x16 Graphics Card
Audio
Features
Audio
  • Integrated High Definition audio with Realtek ALC261 codec (all ports are stereo)
  • Microphone and Headphone front ports
  • Internal Speaker
Software overview
Feature
Operating System
  • Microsoft Windows XP
  • Windows Vista
