    Fix HP Printer issue on macOS
Blinking Lights on the HP Deskjet 3810/3820 Printer Series
The lights on the front of the product indicate the product status. These lights can be on, off, or blinking (flashing), depending on the status of the product. The Power light (), Resume light (), and Cartridge Status light () can all blink in distinct patterns to indicate the product status or potential error conditions.
    Figure : Front panel buttons and lights
    The front panel has the following buttons and lights from top to bottom: Cancel button, Cartridge Status light, Resume button and light, and Power button and light.
  1. Cancel button
  2. Cartridge Status light
  3. Resume button and light
  4. Power button and light
Blinking lights
Printer lights can blink for more than one reason, so the solution can vary. You do not need to perform these solutions in a specific order, but solutions for the most common issues are presented first.
An error message on the computer screen might accompany the blinking lights, and can help determine the solution.
This document describes the light patterns on your product as blinking or flashing lights. In this document, "flashing" means the same as "blinking."
For issues regarding cartridges, first check cartridge compatibility.
Issue: The Power light is blinking
Solution: Wait
The product is preparing to print. The light stops flashing when the product has received all data.
Issue: The Resume light is blinking
Solution one: Load paper
The product might be out of paper.
  1. Load paper into the input tray.
  2. Press the Resume button () to continue the print job.
Solution two: Clear any paper jam
There might be a paper jam. Follow these steps to clear any paper jam from the product.
Step one: Remove any loose paper
Remove any loose sheets of paper from the input tray and the output tray.
Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism.
Step two: Clear the jam from the back of the product
  1. Press the Power button () to turn the product off.
  2. Open the rear access door by pinching the two latch handles and removing the door.
    Figure : Remove the rear door
    Pinch the two latch handles on the right side of the rear door, and then pull the door towards you to remove it.
  3. Remove the paper jam, and then replace the rear access door by gently pushing the door in until it snaps into place.
  4. Load paper into the input tray.
  5. Press the Power button () to turn the product on.
  6. Press the Resume button () to continue the print job.
Step three: Open the cartridge door and clear the jam
  1. Make sure the product is turned on.
  2. Lift the cartridge door to open it.
  3. Disconnect the power cord from the electrical outlet and from the back of the product.
    Make sure the product is turned ON before disconnecting the power cord. Failure to disconnect the power cord from the rear of the product can cause damage when removing jammed paper.
  4. Gently remove any jammed paper.
    Remove the paper jam carefully. It is possible to damage the product when removing paper from the front.
  5. Make sure that no scraps of paper remain between the rollers.
  6. Close the cartridge door.
  7. Plug the power cord into the electrical outlet and to the back of the product.
  8. Press the Resume button () to continue the print job.
Solution three: Print the second side of a two-sided document
The printer might be ready to print the second side of a two-sided document. Follow the instructions that display on your computor for printing the second side.
Issue: The Cartridge Status light is blinking
Solution one: Close the top cover (cartridge door)
The Cartridge Status light blinks when the cartridge door is open. Close the cartridge door, and then press the Resume button () to continue the current print job.
Solution two: Check the cartridge status
The Cartridge Status light flashes when one or both of the cartridges are low on ink, improperly installed, or malfunctioning. The Cartridge Status light also flashes if you are using the wrong cartridge type.
If a cartridge ink level is low, the Cartridge Status light stops flashing when the cartridge door is opened. If the problem is not related to low ink, the light continues to flash after you open the cartridge door.
Follow these steps to check the cartridge status:
Open the cartridge door. The black arrow on the top of the carriage points to one of five cartridge status icons.
    Figure : Check the cartridge status
    The black
arrow on the top of the carriage points to one of five Cartridge Status icons.
  1. Tri-color cartridge problem icon
  2. Black cartridge problem icon
  3. Tri-color cartridge low-ink icon
  4. Black cartridge low-ink icon
  5. Cartridges OK icon
  6. Black indicator arrow on the carriage
If there is a problem with a cartridge, or if a cartridge needs replacing, see Solution three, Solution four, or Solution five below.
Solution three: Remove and then reinsert the cartridge into the product
If the black cartridge icon or tri-color cartridge icon indicates a problem, try removing and then reinserting the cartridge.
  1. Turn the product on, and make sure that the input tray is down.
  2. Open the cartridge door. The carriage moves to the center of the product.
  3. Raise the carriage latch.
  4. Lift the cartridge out of the carriage slot.
      Figure : Remove the cartridge
      Raise the carriage latch and lift up on the cartridge to remove it.
    1. Press the the Power button to turn the product on
  5. Reinsert the cartridge firmly into the slot, and then secure the carriage latch.
Solution four: Clean the cartridges and carriage
If the printer is used in a dusty environment, a small amount of debris might accumulate inside the case. Debris can include dust, hair, carpet, or clothing fibers. Follow the steps below to clean the cartridges and carriage walls.
  1. Open the cartridge door and wait until the carriage moves to the center.
  2. Press the Power button () to turn off the product.
  3. Disconnect the power cord from the back of the product.
  4. Remove the cartridges and place them on a piece of paper with the nozzle plate facing up.
  5. Lightly moisten a cotton swab with distilled water.
  6. Clean the face and edges of the cartridges with the swab. Do not touch the cartridge ink nozzles or the copper contacts.
    Figure : Do not touch the ink nozzle or copper contacts
    Do not touch the copper contacts
  7. With a lightly moistened cotton swab, clean the carriage:
    • Clean the electrical contacts inside the carriage.
    • Wipe the underside of the carriage walls.
        Closeup image of the carriage located inside the product.
      1. Carriage
      2. Carriage walls
  8. Allow the cartridge and the carriage to dry for at least 10 minutes.
  9. Hold the cartridge by its sides with the nozzles toward the product. Slide the cartridge into its empty slot until it clicks into place and is seated firmly in the slot.
  10. Secure the carriage latch, and then close the cartridge door.
  11. Connect the power cord to the back of the product.
  12. Press the Power button () to turn on the product.
Solution five: Replace the cartridge or cartridges
If a cartridge is low on ink, replace the cartridge.
  1. Turn the product on.
  2. Make sure that the input tray is down.
  3. Open the cartridge door. Wait until the carriage moves to the center of the product.
  4. Raise the carriage latch.
  5. Lift the cartridge out of its slot and discard it.
  6. Remove the replacement cartridge from its packaging and carefully remove the plastic tape.
      Figure : Remove the plastic tape
    1. Black cartridge
    2. Color cartridge
    3. Ink nozzles
    4. Copper contacts
    5. Plastic tape
    Do not touch the cartridge ink nozzles or the copper contacts as it might result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. The copper strips are required electrical contacts.
    Figure : Do not touch the copper contacts
  7. Hold the cartridge by its sides with the nozzles toward the product, and then slide the cartridge into its slot.
  8. Secure the carriage latch.
  9. Close the cartridge door.
  10. Try the print job again.
Issue: All lights are blinking
Solution: Restart the product
Follow these steps to restart the product.
  1. Press the Power button () to turn the product off, and then press the Power button again to turn the product on.
    Proceed to Step 2 if the lights continue to blink.
  2. Press the Power button () to turn off the printer.
  3. Disconnect the printer from the power source.
  4. Reconnect the printer to the power source.
  5. Press the Power button () to turn on the printer.
