    Fix HP Printer issue on macOS
HP LE1851w 18.5-inch Widescreen LCD Monitor - Overview
Product description
This HP LE1851w 18.5 inch widescreen LCD monitor for office software, Web and e-mail to provide a clear display.This price economy with a variety of basic functions of the display, and the appearance of fashion, low power consumption can be significant cost savings for you.
Product features
Feature
Model
NK033AA
Type
18.5-inch diagonal widescreen Thin-Film Transistor LCD active matrix (16:9 aspect ratio)
Size / Viewable Image Size (diagonal)
18.5 inches (47 cm) widescreen
Native Resolution
1366 x 768 @ 60 Hz
Signal Input
VGA
Viewing Angle
Up to 160 horizontal/160 vertical (10:1 minimum contrast ratio)
Brightness (typical)
250 nits (cd/m2)
Contrast Ratio (typical)
1000:1
Pixel Pitch
0.3 mm
Horizontal Frequency Range
24 kHz to 83 kHz
Vertical Frequency Range
48 Hz to 76 Hz
User Programmable Modes
10
Plug and Play
Yes
Language Selection
Yes
Anti-Glare
Yes
Anti-Static
Yes
Tilt Range
-5° to + 25° vertical
Swivel Range
None
Height Adjustable
No
Pivot Rotation
No
Base
Detachable, ships detached
Links to product specifications
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
