    Fix HP Printer issue on macOS
HP Indigo WS6000 Digital Press - Replacing ink cans
Replace an ink can when:
  • An ink concentrate can is empty, as indicated by a message displayed by the software.
  • When you want to change the color of ink in an ink tank.
Flush the ink tank before changing the ink color Ink can replacement can be performed while the press is printing.
Wear safety glasses and ink resistant gloves for this procedure.
To replace an ink can:
  1. Open the ink cabinet door.
  2. In the ink cabinet, lift the can up and pull the bottom end out.
    Figure : Ink can replacement
  3. Shake a new can of HP ElectroInk and remove the foil from the can.
  4. Insert the new can in the holder with the nozzle down. Fit the nozzle in the O-ring in the base until the can clicks into place.
  5. Your system updates automatically when you install a new can.
