Replacement Printer Instructions for HP Photosmart Plus B209 All-in-One Printer Series
When HP replaces your defective product, some accessories or parts need to be transferred from the defective product to the replacement product.
  • Some optional accessories might not be included with your product model.
  • Keep any optional accessories that you bought separately.
See below the list of HP Photosmart Plus B209 All-in-One Series printers that are included in this document:
Model name
Product code
HP Photosmart Plus All-in-One B209a Printer
CD035B
HP Photosmart Plus All-in-One B209b Printer
CD035C
HP Photosmart Plus All-in-One B209c Printer
CD045B
Instructions
Prior to replacing or disposing of your defective unit, follow these instructions to ensure the right accessories are removed.
  1. Make sure that the unit is plugged in and turned on before removing the print cartridges and the printhead assembly.
    a) Print cartridges and Printhead assembly
    Do not return nor reuse the print cartridges and printhead assembly. The replacement unit includes a new printhead assembly and a set of new print cartridges.
    • Open the ink cartridge access door by lifting from the front right of the product until the door locks into place and wait until the print carriage stops moving.
    • Press the tab on the front of each cartridge and remove it from the slot.
    • Firmly lift the latch handle on the carriage until it stops.
    • Lift the printhead to remove it from the carriage.
    • Lower the latch handle and close the ink cartridge access door.
      Make sure the latch handle is lowered to its limit. Failure to do so may result in the defective HP All-in-One printer becoming seriously damaged during shipment.
    Then, unplug the HP All-in-One printer and keep the following accessories:
    b) Power supply adapter
    c) Power cord
    d) USB (Universal Serial Bus) cable
    e) Memory cards
    f) Bluetooth adapter
    g) Product manuals and CD
  2. Keep the accessories mentioned above to use with the replacement product.
  3. Power on the replacement product and test all product functions.
  4. For additional support information for your HP product, please visit www.hp.com/support.
Country: Flag Bulgaria
