HP ProBook 4411s Notebook PC - Removing and Replacing the Hard disk drive
This document is provided to assist in removing and replacing the Hard disk drive for the HP ProBook 4411s Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head P000 screwdriver.
Parts required
The replacement part number will vary depending on the Hard disk drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
500 GB SATA hard drive - 5,400 RPM, 2.5 inches form factor, 9.5mm thick - Includes bracket
536414-001 (Modified)
Yes
320 GB SATA hard drive - 5,400 RPM, 2.5 inches form factor, 9.5mm thick - Includes bracket
536413-001 (Modified)
Yes
250 GB SATA hard drive - 7,200 RPM, 2.5 inches form factor, 9.5mm thick - Includes bracket
538972-001 (Modified)
Yes
250 GB SATA hard drive - 5,400 RPM, 2.5 inches form factor, 9.5mm thick - Includes bracket
536412-001 (Modified)
Yes
160 GB SATA hard drive - 7,200 RPM, 2.5 inches form factor, 9.5mm thick - Includes bracket
538971-001 (Modified)
Yes
160 GB SATA hard drive - 5,400 RPM, 2.5 inches form factor, 9.5mm thick - Includes bracket
536411-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Hard disk drive, click on the link below. Or use the product video listing on the HP Services Media Library then select Hard disk drive from the menu on the upper left hand side of the screen.
Click here to view the Hard disk drive removal video (right-click on the link to open in a new window/tab).
  2. Remove the two silver 3mm P000 Phillips-head screws from the left side of the hard disk drive bracket.
  3. Loosen the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  4. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive away from the hard disk drive connector on the system board.
  5. Remove the hard disk drive from the hard disk drive bay.
  6. Place the hard disk drive in an electrostatic dissipating bag.
Hard disk drive replacement
  1. Remove the hard disk drive from the electrostatic dissipating bag.
  2. Place the hard disk drive into the hard disk drive bay and align it with the hard disk drive connector on the system board.
  3. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive securely onto the hard disk drive connector.
  4. Tighten the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Replace the two silver 3mm P000 Phillips-head screws on the left side of the hard disk drive bracket.
Parts return
