HP Scitex FB950 - Control panel Menu tree
more recent versions. Options marked with (*) are dynamically hidden depending on the printer mode.
Calibrate Printer
  • Auto Calibrations
    • AutoBidi Calibration
    • AutoH2H Calibration
    • AutoJet Calibration
    • Full AutoSet
    • AutoSet Summary
  • Manual Calibrations
    • Manual Bidi Registration
    • Printhead X Calibration
    • Manual Jet Mapping
    • Jet Status Lines
    • Media Feed Calibration
    • Print Jet-Out Lines
    • Default Registration Data
  • *AutoTune (Rollfed printing only)
    Printer Settings
  • *Special Modes (sheetfed printing)
    • Edge-To-Edge (Sides Only)
    • Edge-To-Edge (All 4 Edges)
  • Margins
  • *Space Between Prints (Rollfed)
  • Print Position
  • *Measure Media (Sheetfed)
  • Print White Space
  • Head Height off Media
  • *Eject Sheets to Input Side (Sheetfed)
  • Purge Type
  • Top Gutters
  • Quality Check
  • Sleep Wait Time
  • Expert/Novice Messages
  • Localization
    • Units of Measure
    • Time Format
    • Date Format
    • Vacuum Pressure Units
    • *Language (if second language present)
    • *Delete Language (if second language present)
  • Use Thickness Sensor
  • Use Ionizer Bar
  • Low Ink Warning
  • UV Lamps Idle Time
  • Support Rollfed
  • Use Service Station Float
  • Printer Name
  • Restore All Defaults
    Tools
  • System Information
  • Maintenance
    • Access Printheads
    • Perform An Air Purge
    • Print Recover Jets Pattern
    • Print Media Skew Lines
    • Reset UV Lamp Hours
    • Clean Media Drive Belt & Encoder
    • Printheads Procedures — Load Ink In All Heads, Fill Heads with Ink, Empty Heads (Fill with Air)
  • User Diagnostics
    • Printhead Jet Statistics
    • VideoNet Status
    • VideoNet Connection
    • Carriage Motion
    • Calibration
    • Vacuum Pressure
    • Open Loop Actuator Test
    • Open Loop Service Station Test
    • Warnings and Actions List
    • Error History
    • Log Error History
    • Log System Info
    *Warnings & Actions (In Expert Mode only)
    Service Printer (for service provider use only)
    Print Menus
