HP LE1901wm 19-inch Widescreen LCD Monitor Product Specification
Product Description
Combining essential performance features in an elegant, ENERGY STAR qualified design, the updated HP LE1901wm 19- inch Widescreen LCD Monitor offers improved energy efficiency over its predecessor.
Product Features
Feature
Type
48.14 cm (19 inches) Wide-Aspect Active Matrix TFT (thin film transistor)
Viewable Image Area (diagonal)
48.14 cm (19 inches) wide (WXGA+); diagonally measured
Native Resolution
1440 x 900 @ 60 Hz
Signal Input
VGA, DVI-D (cables included)
Horizontal Viewing Angle
Up to 160o horizontal/160o vertical (10:1 minimum contrast ratio)
Cabinet Colors
Black
Brightness (typical)
250 nits (cd/m2)
Contrast Ratio (typical)
1000:1
Pixel Pitch
.2835 mm
Horizontal Frequency Range
24 to 83 kHz
Vertical Frequency Range
50 to 76 Hz
User Programmable Modes
Plug and Play
Yes
Language Selection
Yes
Anti-Glare
Yes
Anti-Static
No
Swivel
No
Tilt Range
-5o to + 25o vertical
Height Adjustable
No
Pivot Rotation
No
Base
Detachable, ships detached
Mechanical
Feature
Specification
Dimensions (H x W x D)
Unpacked w/stand
37.0 x 44.6 x 20.6 cm (14.6 x 17.6 x 8.1 inches)
Unpacked w/o stand (head only)
30.1 x 44.6 x 5.9 cm (11.9 x 17.6 x 2.3 inches)
Packaged
44.5 x 51.3 x 13.2 cm (17.6 x 20.2 x 5.2 inches)
Unpacked
4.3 kg (9.5 lb)
Head only
4.0 kg (8.8 lb)
Packaged
5.7 kg (12.6 lb)
Tilt Range
Swivel Range
No
Height Adjustable
No
Pivot Rotation
Nos
Base
Panel
Feature
Specification
Type
48.14-cm (19 inches) Wide-Aspect Active Matrix TFT (thin film transistor)
Screen Opening (W x H)
40.82 x 25.52 cm (16.1 x 10.0 inches)
Panel Type
TN
Aspect Ratio
16:10
Viewing Angle (typical)
Brightness (typical)1
250 nits (cd/m2)
Contrast Ratio (typical)1
1000:1
Response Time (typical)1
≤5 ms (on/off)
Pixel Pitch
.2835 mm
Backlight Lamp Life (to half brightness)
50 K hours
Color Gamut
72%
Note 1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
On Screen Display (OSD) Controls
Feature
Specification
Buttons or Switches
Auto adjust/OSD down, OSD UP, OSD menu select, power
Languages
English, French, German, Spanish, Italian, Dutch, and Japanese, S. Chinese, Portuguese
User Controls
Brightness, contrast, positioning, color temperature (6500k, 9300k, custom), individual color control, serial number, display, clock, clock phase, monitor management, factory reset, zoom
24 to 83 kHz
Signal Interface/ Performance
Feature
Specification
Vertical Frequency
50 to 76 Hz
Native Resolution
1440 x 900 @ 60 Hz
Preset VESA Graphic Modes (non-interlaced)
  • 1440 x 900 @ 60 Hz
  • 1280 x 1024 @ 60 Hz and 75 Hz
  • 1280 x 960 @ 60 Hz
  • 1024 x 768 @ 60 Hz and 75 Hz
  • 800 x 600 @ 60 Hz and 75 Hz
  • 640 x 480 @ 60 Hz and 75 Hz
CVT Mode
  • 1152 x 720 @ 60 Hz
  • 1280 x 768 @ 60 Hz
Text Mode
720 x 400 @ 70 Hz
Mac Mode
1152 x 870 @ 75 Hz and 832 x 624 @ 75 Hz
Sun Mode
1152 x 900 @ 66 Hz
Maximum Pixel Clock Speed
140 MHz (analog input)
Yes, 15
Anti-Glare
Yes
Anti-Static
No
Default Color Temperature
6500 K
Video/Other Inputs
Feature
Specification
Plug and Play
Yes
Self Powered USB 2.0 Hub
No
Input Signal
Input Impedance
75 ohms ± 10%
Sync Input
TTL separate synch or Composite Sync
Audio
Feature
Specification
Speakers
Integrated rear firing
Output power
2 watt per channel
Controls
Volume, OSD selectable
Audio cable
Included, length: 5.9 ft (1.8 m)
Power
Feature
Specification
Input Power
Auto-Sensing, 90 to 265 VAC,
Frequency
45 to 63 Hz
Typical Power Consumption
22.8 watts
Maximum
29.0 watts
Power Saving
2 watts standby;1 watt off
Power Cable Length
6.2 ft (1.9 m)
Environmental
Feature
Specification
Temperature
Operating
-34° to 60° C ( -29° to 140° F)
Non-operating
-20° to 60° C (-4° to 140° F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%, 38.7° C max wet-bulb
Altitude
Operating
3,658 m (+12,000 feet)
Non-operating
12,192 m (+40,000 feet)
Warranty Information
Limited 3 years parts, labour and on-site service, including backlight.
