Printer Specifications for HP Photosmart Premium All-in-One Printers (C309g and C309h)
Product specifications
This document contains specifications for the product, including model numbers, system requirements, and print speed.
HP Photosmart Premium C309g All-in-One models
Figure : HP Photosmart Premium C309g All-in-One Printer
Illustration: HP Photosmart Premium C309g All-in-One Printer
All-in-One Model
Product numbers
CD054A
CD055A
CD055B
CD055D
CD056A
CD061C
System requirements
The following tables contain the minimum system requirements and recommended system requirements for supported Windows and Macintosh operating systems.
Windows system requirements
Supported Windows operating systems: Windows XP, Windows Vista
For Windows XP SP 1 Starter Edition, and Windows Vista Starter Edition only the print driver and Toolbox are available.
Component
Minimum system requirement
Recommended system requirement
Processor
Windows XP (32-bit) Service Pack 2
Intel Pentium II or Celeron processor
Intel Pentium III or higher processor
Windows Vista
800 MHz 32-bit (x86) or 64-bit (x64) processor
1 GHz 32-bit (x86) or 64-bit (x64) processor
RAM
512 MB
512 MB
Windows Vista
512 MB
1 GB
Free disk space
225 MB
360 MB
Windows Vista
902 MB
1056 MB
Browser
Microsoft Internet Explorer 6.0 or later
Windows Vista
Microsoft Internet Explorer 7.0
Other
Adobe Acrobat Reader 5.0 or later
Macintosh system requirements
Supported Macintosh operating systems: Mac OS X v10.4, v10.5, v10.6, and v10.7.
Component
Processor
Mac OS X 10.4, 10.5, and 10.6
PowerPC with G3, G4, G5, or Intel Core Duo processor
OS X 10.7
Intel Core 2 Duo processor
Intel Core 2 Duo or higher processor
Memory
256 MB
512 MB or higher
OS X 10.7
2 GB
2 GB or higher
Browser
Any browser
Free disk space
500 MB
800 MB or higher
Other
CD-ROM or DVD-ROM drive
Available USB port and USB cable
Adobe Acrobat Reader 5.0 or later (recommended)
Quick Time 5.0 or later (recommended)
SVGA 800 x 600 monitor with 16-bit color (32-bit color recommended)
Internet access (recommended)
Physical dimensions
The dimensions listed are for the product without the power supply attached.
Height
199 mm (7.83 inches)
Width
452 mm (17.8 inches)
Depth
473 mm (18.62 inches) with tray extender open
390 mm (15.4 inches) with tray extender closed
7.45 kg (16.4 pounds)
Americas and Asia Pacific (excluding China, India, and Japan)
Western Europe
Africa, CIS, Japan, and Middle East
China and India
Ink cartridge
HP 564
HP 364
HP 178
HP 862
Visit HP SureSupply to check ink or toner cartridge compatibility or purchase replacement cartridges and other supplies.
  1. If necessary, select your country/region.
    Figure : Country/region selector
    Selecting your country/region
  2. Follow the on-screen instructions to order new supplies or check cartridge compatibility with your printer.
You can also purchase genuine HP cartridges and supplies from other retailers.
Input/output
  • USB port: Rear hi-speed, front PictBridge port for storage devices
  • Memory card slots: Memory Stick, Memory Stick Pro, Memory Stick Select, Memory Stick Magic Gate, Memory Stick Duo, Pro Duo, or Pro-HG Duo (adapter optional), or Memory Stick Micro (adapter required), MultiMediaCard (MMC), MMC Plus, Secure MMC, MMC Mobile (RS-MMC; adapter required), Secure Digital (SD), Secure Digital Mini, Secure Digital High Capacity (SDHC), TransFlash MicroSD Card (adapter required), xD Type M, or xD Type H.
  • Wireless network: 802.11 supported
  • Ethernet port: 802.3 supported (RJ-45 connector)
  • Bluetooth wireless printing: Supported (Windows Vista or Windows XP and either the Microsoft Bluetooth® Protocol Stack or the Widcomm Bluetooth® Protocol Stack required)
Paper-handling specifications
The following tables contain specifications for supported paper.
Paper tray capacities
Paper Type
Paper weight
Input tray (maximum capacity)
Output tray*
Photo tray (maximum capacity)
Plain paper
75 to 90 gsm (20 to 24 lb)
Up to 125 (20 lb paper)
50 (20 lb paper)
n/a
Legal paper
Up to 100 (20 lb paper)
10 (20 lb paper)
n/a
Cards
200 gsm (110 lb index max)
Up to 20
25
Up to 20
Envelopes
Up to 15
n/a
Transparency film
n/a
Up to 40
25
n/a
Labels
n/a
Up to 40
25
n/a
13 x 18 cm (5 x 7 inch) Photo paper
236 gsm (145 lb)
Up to 20
20
Up to 20
10 x 15 cm (4 x 6 inch) Photo paper
236 gsm (145 lb)
Up to 20
20
Up to 20
216 x 279 mm (8.5 x 11 inch) Photo paper
n/a
Up to 40
25
n/a
*Output tray capacity is affected by the type of paper and the amount of ink you are using. HP recommends emptying the output tray frequently. FAST DRAFT print quality mode requires the extender tray to be extended and the end tray rotated up.
Paper sizes
The following table contains lists of supported paper sizes.
Paper Type
Size
Letter
216 x 279 mm (8.5 x 11 inches)
Legal
216 x 356 mm (8.5 x 14 inches)
A4
210 x 297 mm (8.3 x 11.7 inches)
HV
101 x 180 mm (3.98 x 7.09 inches)
Photo card with tab
100 x 200 mm (3.9 x 7.9 inches)
B7 (JIS)
91 x 128 mm (3.6 x 5 inches)
B7 (ISO)
88 x 125 mm (3.5 x 4.9 inches)
Photo paper
varies - see photo paper specifications
Paper types
The following table contains lists of supported paper types.
Paper Type
Dimension
Specification
Supported envelopes
#10
Up to 15 envelopes
Supported transparencies
Up to 40 sheets
n/a
Supported labels
Letter 216 x 279 mm (8.5 x 11 inches)
Up to 25 sheets
Photo Paper
The following tables contain information on supported photo paper
Supported borderless photo paper
Photo paper type
Size
10 x 15 cm
100 x 150 mm (3.9 x 5.9 inches)
13 x 18 cm
130 x 180 mm (5.1 x 7.1 inches)
4 x 6 inch
101.6 mm x 152.4 mm (4 x 6 inches)
4 x 6 inch with tab
4 x 8 inch with tab
101.6 mm x 203.2 mm (4 x 8 inches)
2L
127 x 178 mm (5 x 7 inches)
3.5 x 5 inch
89 x 127 mm (3.5 x 5 inches)
5 x 7 inch
A6
105 x 148 mm (4.1 x 5.8 inches)
A4
A5
148 x 210 mm (5.8 x 8.3 inches)
B5
182 x 257 mm (7.2 x 10.1 inches)
Cabinet
120 x 165 mm (4.7 x 6.5 inches)
Double A4
210 x 594 mm (8.3 x 23.4 inches)
Hagaki
100 x 148 mm (3.9 x 5.8 inches)
L
Letter
4 x 11 inch
102 x 279 mm (4 x 11 inches)
4 x 12 inch
102 x 305 mm (4 x 12 inches)
10 x 28 cm
100 x 280 mm (3.9 x 11.02 inches)
10 x 30 cm
100 x 300 mm (3.9 x 11.8 inches)
HV
B7 (JIS)
B7 (ISO)
10 x 15 cm with tab
Supported photo paper with borders
Paper type
Paper size
A4
3.5 x 5 inch
4 x 6 inch
4 x 6 inch with tab
5 x 7 inch
10 x 15 cm
Letter
Hagaki
L
Printing specifications
Category
Specification
Resolution
9600 dpi print
Method
Drop-on-demand thermal inkjet
Language
PCL3 GUI
Print speed* (varies by model)
Black: After the first page, up to 33 ppm
Color: After the first page, up to 32 ppm
*See www.hp.com/go/inkjetprinter for details.
Copying specifications
  • Digital image processing
  • Maximum number of copies: Varies by model
  • Copy speed*: Up to 33 pages per minute (ppm) black, up to 32 ppm color
  • Maximum copy enlargement ranges from 200-400% (depends on model)
  • Maximum copy reduction ranges from 25-50% (depends on model)
  • Maximum copies: 99 from control panel (depends on model)
Scanning specifications
  • Image editor included
  • Twain-compliant software interface
  • Resolution: up to 4800 x 4800 ppi optical (depends on model); 19200 ppi enhanced (software)
  • Color: 48-bit color, 8-bit grayscale (256 levels of gray)
  • Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
Power specifications
Category
Specification
Average power consumption
42 watts maximum
Input voltage (0957-2231)
AC 100 to 240 V ~
Output current
1300 mA
Input frequency
50–60 Hz
Output voltage
DC 32 V===1300 mA
Environmental specifications
In the presence of high electromagnetic fields, it is possible that the output from the product might be slightly distorted.
HP recommends using a USB cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to high electromagnetic fields.
Recommended operating conditions
Recommended operating temperature range: 15 ºC to 32 ºC (59 ºF to 90 ºF)
Humidity: 15% to 80% RH non-condensing
Maximum operating conditions
Allowable operating temperature range: 5 ºC to 35 ºC (41 ºF to 95 ºF)
Storage conditions
Temperature range: –20 ºC to 50 ºC (–4 ºF to 122 ºF)
This product is designed to reduce power consumption and save natural resources without compromising product performance. It has been designed to reduce total energy consumption both during operation and when the device is not active. This product qualifies for ENERGY STAR®, which is a voluntary program established to encourage the development of energy-efficient office products.
Figure : Energy Star logo
ENERGY STAR is a U.S. registered service mark of the U.S. EPA. As an ENERGY STAR partner, HP has determined that this product meets ENERGY STAR guidelines for energy efficiency.
For more information, go to the Energy Star Web site (in English).
To view Material Safety Data Sheets (MSDS), go to http://www.hp.com/go/msds (in English).
This product is suited for the use of recycled paper according to DIN 19309 and EN 12281:2002. Plastic parts over 25 grams (0.88 ounces) are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of product life.
HP offers an increasing number of product return and recycling programs in many countries and regions, and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. For more information about the recycling of HP products, go to www.hp.com/hpinfo/globalcitizenship/environment/recycle/ (in English).
Regulatory specifications
The product requirements from regulatory agencies in your country/region. For a complete listing of regulatory notices, see the onscreen Help.
Regulatory model identification number
For regulatory identification purposes, your product is assigned a Regulatory Model Number. The Regulatory Model Number for your product is SDGOB-0914. This regulatory number should not be confused with the marketing name (HP Photosmart Premium C309g, etc.) or product numbers (CD055A,, etc.).
Exposure to radio frequency radiation
The radiated output power of this device is far below the FCC radio frequency exposure limits. Nevertheless, the device shall be used in such a manner that the potential for human contact during normal operation is minimized. This product and any attached external antenna, if supported, shall be placed in such a manner to minimize the potential for human contact during normal operation. In order to avoid the possibility of exceeding the FCC radio frequency exposure limits, human proximity to the antenna shall not be less than 20 cm (8 inches) during normal operation.
Country: Flag Bulgaria
