HP LE2001w 20-inch Widescreen LCD Monitor - Specifications
Part number and RoHS information
IMPORTANT:: To obtain current part number information for this product, including RoHS-compliant and orderable spare parts, please use one of the following utilities:
  • HP PartSurfer at the URL http://partsurfer.hp.com. (To report missing or incorrect parts information in PartSurfer, please use the "Contact us" and "Missing or incorrect data" links within the utility.)
    To lookup RoHS-compliant information in PartSurfer, use the component’s option part number or the sales order number for a system in which the component is used (available in the QuickSpecs or Standard Models page).
  • Click here to see a list of HP LE2001w Widescreen LCD Monitor models on the PartSurfer Page. Select the SKU number for a monitor to get the list of spare part numbers.
Widescreen LCD Panel
Feature
Type
20.0-inch Wide-Aspect Active Matrix TFT (thin film transistor)
Viewable Image Area (diagonal)
20.0 inches widescreen; diagonally measured
Screen Opening (W x H)
44.3 x 24.9 cm (17.42 x 9.79 inches)
Viewing Angle (typical)
Up to 170o horizontal/160o vertical (700:1 minimum contrast ratio)
Panel Type
TN
Aspect Ratio
16:9
Brightness (typical)
250 nits (cd/m2)
Contrast Ratio (typical)
1000:1
Response Time (typical)
5 ms (On/Off)
Pixel Pitch
0.2768 mm
Backlight Lamp Life (to half brightness)
50K hours
Color Gamut
72%
Note 1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower. On Screen Display (OSD) Controls Buttons or Switches OSD menu select, OSD down, OSD UP,
Feature
Buttons or Switches
OSD menu select, OSD down, OSD UP, Ok/auto adjust, power
Language
English, French, German, Spanish, Italian, Japanese, S. Chinese. T. Chinese, Netherlands, and Portuguese
User Controls
Brightness, contrast, positioning, color temperature (6500k, 9300k, sRGB, custom), individual color control, serial number, display, clock, clock phase, monitor management, factory reset, scaling
Signal Interface/ Performance
Feature
Horizontal Frequency
24 to 85 kHz
Vertical Frequency
48 to 76 Hz
Native Resolution
1600 x 900 @ 60 Hz (WSXGA+)
Preset VESA Graphic Modes (non-interlaced)
  • 640 x 480 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1440 x 900 @ 60Hz
Text Mode
720 x 400 @ 70 Hz
Mac Mode
TBD
Sun Mode
TBD
Maximum Pixel Clock Speed
170 MHz (analog input)
User Programmable Modes
Yes, 8
Anti-Glare
Yes
Anti-Static
Yes
Default Color Temperature
6500 K
Video/Other Inputs
Feature
Plug and Play
Yes
Self Powered USB 2.0 Hub
No
Input Connectors
VGA connector
Input Impedance
75 ohms
Sync Input
TTL separate synch or Composite Sync
Video Cables
1 VGA
VGA Cable Length
1.8 m ( 5.9 feet)
Power
Feature
Input Power
Auto-Sensing, 100 to 240 VAC, 50 +/-3 Hz to 60 +/-3 Hz)
Frequency
45 to 63 Hz
Typical Power Consumption
26 watts
Maximum
< 28 watts
Power Saving
< 2 watts standby; < 1 watt off
Power Cable Length
6.2 ft (1.9 m)
Mechanical
Feature
Dimensions (H x W x D)
Unpacked w/stand
47.86 x 36.05 x 20.6 cm (18.84 x 14.19 x 8.11 inches)
Unpacked w/o stand (head only)
47.86 x 28.9 5.5 cm (18.84 x 11.38 x 2.16 inches)
Packaged
45 x 54 x 14 cm (17.62 x 21.26 x 5.51 inches)
Unpacked
4.3 kg (9.48 lbs)
Packaged
6 kg (13.23 lbs)
Head only
3.7kg (8.16 lbs)
Tilt Range
-5° to + 25° vertical
Swivel Range
No
Height Adjustable
No
Pivot Rotation
No
Base
Detachable, ships detached
Environmental
Feature
Temperature - Operating
41o to 95o F (5o to 35o C)
Temperature - Nonoperating
-29o to 140o F (-20o to 60o C)
Humidity - Operating
20% to 80% non-condensing
Humidity - Non-operating
5% to 95%, 38.7o C max wet-bulb
Altitude - Operating
3,658 m (+12,000 feet)
Altitude - Non-operating
12,192 m (+40,000 feet)
