    We are upgrading our website
    Fix Windows 10 Update Issues
HP LE1901w 19-inch Widescreen LCD Monitor Product Specifications
Product description
HP LE1901w 19 inch Widescreen LCD Monitor is with Essential performance features in an elegant, ENERGY STAR qualified design that offers improved energy efficiency. 50% reduction in mercury over previous generation models, elimination of BFR, PVC, and arsenic from the panel and stand, and minimized power consumption.
Product features
Feature
Model
NK570AA
Type
48.14 cm (19 inches) Wide-Aspect Active Matrix TFT (thin film transistor)
Size / Viewable Image Size (diagonal)
48.14 cm (9 inches) wide (WXGA+); diagonally measured
Native Resolution
1440 x 900 @ 60 Hz
Signal Input
15 pin D-sub VGA
Horizontal Viewing Angle
Up to 1600
Vertical Viewing Angle
160o (10:1 minimum contrast ratio)
Cabinet Colors
Black
Image Quality
Brightness (typical)
250 nits (cd/m2)
Contrast Ratio (typical)
1000:1
Pixel Pitch
.2835 mm
Horizontal Frequency Range
24 to 83 kHz
Vertical Frequency Range
50 to 76 Hz
Ease of Use Feature
User Programmable Modes
Plug and Play
Yes
Language Selection
Yes
Ergonomic Features
Anti-Glare
Yes
Anti-Static
Yes
Tilt/Swivel
Yes
Panel
Feature
Type
48.14 cm (9 inches) Wide-Aspect Active Matrix TFT (thin film transistor)
Viewable Image Area (diagonal)
48.14 cm (19 inches) wide (WXGA+); diagonally measured
Screen Opening (W x H)
40.82 x 25.52 cm (16.1 x 10.0 inches)
Panel Type
TN
Aspect Ratio
16:10
Viewing Angle (typical)
Up to 160o horizontal/160o vertical (10:1 minimum contrast ratio)
Brightness (typical)1
250 nits (cd/m2)
Contrast Ratio (typical)1
1000:1
Response Time (typical)1
=5 ms (On/Off)
Pixel Pitch
.2835 mm
Backlight Lamp Life (to half brightness)
50 K hours
Color Gamut
72%
Note 1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
On Screen Display (OSD) controls
Feature
Buttons or Switches
Auto adjust/OSD down, OSD UP, OSD menu select, power
Languages
English, French, German, Spanish, Italian, Dutch, and Japanese, S. Chinese, Portuguese
User Controls
Brightness, contrast, positioning, color temperature (6500k, 9300k, custom), individual color control, serial number, display, clock, clock phase, monitor management, factory reset, zoom
Signal interface/ Performance
Feature
24 to 83 kHz
Vertical Frequency
50 to 76 Hz
Native Resolution
1440 x 900 @ 60 Hz
Preset VESA Graphic Modes (non-interlaced)
  • 1280 x 1024 @ 60 Hz and 75 Hz
  • 1280 x 960 @ 60 Hz
  • 1024 x 768 @ 60 Hz and 75 Hz
  • 800 x 600 @ 60 Hz and 75 Hz
  • 640 x 480 @ 60 Hz and 75 Hz
CVT Mode
  • 1152 x 720 @ 60 Hz
  • 1280 x 768 @ 60 Hz
Text Mode
720 x 400 @ 70 Hz
Mac Mode
1152 x 870 @ 75 Hz and 832 x 624 @ 75 Hz
Sun Mode
1152 x 900 @ 66 Hz
Maximum Pixel Clock Speed
140 MHz (analog input)
Yes, 15
Anti-Glare
Yes
Anti-Static
No
Default Color Temperature
6500 K
Video/Other inputs
Feature
Plug and Play
Yes
Self Powered USB 2.0 Hub
No
Input Signal
VGA
Input Impedance
75 ohms ± 10%
Sync Input
TTL separate synch or Composite Sync
VGA Cable
15 pin D-sub VGA
VGA Cable Length
5.9 ft (1.8 m)
Power
Feature
Input Power
Auto-Sensing, 90 to 265 VAC
Frequency
45 to 63 Hz
Typical Power Consumption
22.8 watts
Maximum
29.0 watts
Power Saving
2 watts standby;1 watt off
Power Cable Length
1.9 m (6.2 feet )
Physical specifications
Feature
Dimensions (H x W x D)
Unpacked w/stand
37.0 x 44.6 x 20.6 cm (14.6 x 17.6 x 8.1 inches)
Unpacked w/o stand (head only)
30.1 x 44.6 x 5.9 cm (11.9 x 17.6 x 2.3 inches)
Packaged
44.5 x 51.3 x 13.2 cm (17.6 x 20.2 x5.2 inches)
Unpacked
4.3 kg (8.96 lb)
Head only
4.0 kg (8.8 lb)
Packaged
5.7 kg ( 12.6 lb)
Tilt Range
-5o to + 25o vertical
Swivel Range
No
Height Adjustable
No
Pivot Rotation
No
Base
Detachable, ships attached
Environmental
Feature
Temperature - Operating
-34o to 60o C (-29o to 140o F )
Temperature - Nonoperating
-20o to 60o C (-4o to 140o F )
Humidity - Operating
20% to 80% non-condensing
Humidity - Non-operating
5% to 95%, 38.7o C max wet-bulb
Altitude - Operating
3,658 m (+12,000 ft)
Altitude - Non-operating
12,192 m (+40,000 ft)
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
