HP Compaq dx2400 Business Desktop PC Specifications
Product description
A professional chassis design offers easy-to-access ports, slots and bays; available with pre-installed business applications so you can get started quickly and be productive the first time you boot up your new PC.
Product features
Feature
Form factor
Microtower
Processor
Intel Celeron Processors
  • Intel Celeron 420 Processor (1.60-GHz, 512-KB L2 cache, 800-MHz FSB)
  • Intel Celeron 430 Processor (1.80-GHz, 512-KB L2 cache, 800-MHz FSB)
  • Intel Celeron 440 Processor (2.00-GHz, 512-KB L2 cache, 800-MHz FSB)
  • Intel Celeron Dual Core E1200 Processor (1.60-GHz, 512-KB L2 cache, 800-MHz FSB)
  • Intel Celeron Dual Core E1400 Processor (2.0-GHz, 512-KB L2 cache, 800-MHz FSB)
Intel Pentium Processors
  • Intel Pentium Dual Core E2140 Processor (1.60-GHz, 1-MB L2 cache, 800-MHz FSB)
  • Intel Pentium Dual Core E2160 Processor (1.80-GHz, 1-MB L2 cache, 800-MHz FSB)
  • Intel Pentium Dual Core E2180 Processor (2.0-GHz, 1-MB L2 cache, 800-MHz FSB)
  • Intel Pentium Dual Core E2200 Processor (2.20-GHz, 1-MB L2 cache, 800-MHz FSB)
Intel Core 2 Processors
  • Intel Core 2 Duo E4500 Processor (2.20-GHz, 2-MB L2 cache, 800-MHz FSB)
  • Intel Core 2 Duo E4600 Processor (2.40-GHz, 2-MB L2 cache, 800-MHz FSB)
  • Intel Core 2 Duo E4700 Processor (2.60-GHz, 2-MB L2 cache, 800-MHz FSB)
  • Intel Core 2 Duo E6550 Processor (2.33-GHz, 4-MB L2 cache, 1333-MHz FSB)
  • Intel Core 2 Duo E6750 Processor (2.66-GHz, 4-MB L2 cache, 1333-MHz FSB)
  • Intel Core 2 Duo E6850 Processor (3.00-GHz, 4-MB L2 cache, 1333-MHz FSB)
  • Intel Core 2 Duo E7200 Processor (2.53-GHz, 3-MB L2 cache, 1066-MHz FSB)
  • Intel Core 2 Duo E7300 Processor (2.66-GHz, 3-MB L2 cache, 1066-MHz FSB)
  • Intel Core 2 Duo E8200 Processor (2.66-GHz, 6-MB L2 cache, 1333-MHz FSB)
  • Intel Core 2 Duo E8400 Processor (3.00-GHz, 6-MB L2 cache, 1333-MHz FSB)
  • Intel Core 2 Duo E8500 Processor (3.16-GHz, 6-MB L2 cache, 1333-MHz FSB)
  • Intel Core 2 Quad Q9300 Processor (2.50-GHz, 6-MB L2 cache, 1333-MHz FSB)
  • Intel Core 2 Quad Q9450 Processor (2.66-GHz, 12-MB L2 cache, 1333-MHz FSB)
Intel processor numbers are not a measure of performance. Processor numbers differentiate features within each processor family, not across different processor families.
Intel G33 Express
Memory
  • 512-MB DDR2 Synch DRAM PC2-6400 (800-MHz) Non-ECC (1 x 512MB)
  • 1-GB DDR2 Synch DRAM PC2-6400 (800-MHz) Non-ECC (1 x 1GB)
  • 2-GB DDR2 Synch DRAM PC2-6400 (800-MHz) Non-ECC (2 x 1GB)
  • 2-GB DDR2 Synch DRAM PC2-6400 (800-MHz) Non-ECC (1 x 2GB)
  • 3-GB DDR2 Synch DRAM PC2-6400 (800-MHz) Non-ECC (3 x 1GB)
  • 4-GB DDR2 Synch DRAM PC2-6400 (800-MHz) Non-ECC (4 x 1GB)
  • 4-GB DDR2 Synch DRAM PC2-6400 (800-MHz) Non-ECC (2 x 2GB)
  • 8-GB DDR2 Synch DRAM PC2-6400 (800-MHz) Non-ECC (4 x 2GB)
Hard drive(s)
  • 80-GB Serial ATA 3.0-Gb/s NCQ, Smart IV (7200 rpm)
  • 160-GB Serial ATA 3.0-Gb/s NCQ, Smart IV (7200 rpm)
  • 250-GB Serial ATA 3.0-Gb/s NCQ, Smart IV (7200 rpm)
  • 500-GB Serial ATA 3.0-Gb/s NCQ, Smart IV (7200 rpm)
Storage
Diskette Drive
  • 1.44-MB Diskette Drive
Media Reader
  • HP 16-in-1 Media Reader and additional USB 2.0 port
Optical Drives (Serial ATA)
  • SATA DVD-ROM Drive
  • SATA CD-RW/DVD-ROM Combo Drive
  • SATA SuperMulti LightScribe DVD Writer Drive
Graphics
  • Intel Graphics Media Accelerator 3100 - integrated
  • NVIDIA GeForce 8400 GS (256MB) Single Head PCIe x16 - optional
    1GB of system memory required. Graphics cards use part of the total system memory to enhance graphics performance.
  • HP ADD2 SDVO PCIe x16 DVI-D Adapter - optional
  • ATI Radeon HD 2400XT (256MB DH) PCIe x16 - optional
  • ATI Radeon HD 3650 (512MB DH) PCIe x16 - optional
Audio
  • Realtek ALC888S High Definition audio codec
  • 3D audio compliant and HD Audio compatible
  • Internal PC speaker
Communications
  • Integrated Realtek 8111C-GR GbE Ethernet Controller
  • Intel PRO/1000 PT Gigabit PCIe Controller (full height) - optional
  • Agere 56K PCI Modem - optional
  • HP Wireless A+G PCI Card (full height) - optional
Input devices
Keyboard (One of the following)
  • HP PS/2 Standard Keyboard
  • HP USB Standard Keyboard
Mouse (One of the following)
  • PS/2 2-Button Optical Scroll Mouse
  • USB 2-Button Optical Scroll Mouse
  • USB 2-Button Laser Mouse
Hardware specifications
Features
Power supply
300W ATX power supply – PFC/non-PFC with a 115v/230v line switch (varies by country/region)
Front I/O
Two (2) USB 2.0 ports
Rear I/O
Standard Micro ATX I/O connectors, including four (4 ) USB 2.0 ports
Communication features
Integrated Realtek 8111C-GR GbE Ethernet Controller; Intel PRO/1000 PT Gigabit PCIe Controller (full height) – optional
Storage
Drive Bays
  • Internal: 2 - 3.5 inch
  • External: 1 - 3.5 inch; 2 - 5.25-inch
  • 80 GB 7200 rpm SATA 3.0 Gb/s NCQ, Smart IV
  • 160 GB 7200 rpm SATA 3.0 Gb/s NCQ, Smart IV
  • 250 GB 7200 rpm SATA 3.0 Gb/s NCQ, Smart IV
  • 320 GB 7200 rpm SATA 3.0 Gb/s NCQ, Smart IV
  • 500 GB 7200 rpm SATA 3.0 Gb/s NCQ, Smart IV
Optical Drives
SATA DVD; SATA DVD/CD-RW combo; SATA SuperMulti LightScribe DVD Writer
Audio, slots, and ports
Features
Audio
Realtek ALC888S High Definition audio codec; 3D audio compliant and HD Audio compatible; Internal PC speaker
I/O Ports
  • External:
    • 2 USB 2.0
    • 1 microphone in
    • 1 headphone/line-out
  • Rear:
    • 4 USB 2.0; 2 PS/2; 1 external VGA monitor; 1 audio in; 1 audio out; 1 RJ-45; 1 microphone in
Slots
  • 1 full-height PCI 2.3
  • 2 full-height PCIe x1
  • 1 full-height PCIe x16
Physical specifications
Feature
Chassis Dimensions (H x W x D)
15.16 x 7.28 x 16.38 inch with bezel (385 x 185 x 416 mm)
14.88 x 6.50 x 16.10 inch without bezel (378 x 165 x 409 mm)
Packaged Dimensions (L x W x H)
19.13 x 21.875 x 10.13 inch
490 x 556 x 257 mm
System weight
22.4 lb (10.2 kg)
Shipping Weight
30.8 lb (14.0 kg)
Software/OS
Feature
Operating System
  • Genuine Windows Vista Ultimate 32 (English Only)*
  • Genuine Windows Vista Home Basic 32
  • Genuine Windows Vista Business with Genuine Windows XP Professional custom pre-installed
  • FreeDOS
Application Software
  • Microsoft Office 2007 Basic
  • Microsoft Office 2007 Small Business
  • Microsoft Office 2007 Professional
  • Microsoft Works 8.5
  • Roxio Easy Media Creator 9.x
    Supporting software available with certain optical drive configurations
  • Intervideo WinDVD Player 5.x
  • McAfee Total Protection Service
  • Sun Java Runtime Environment
  • AOL Toolbar
Environmental specifications
  • Values are subject to change without notification and are for reference only.
  • Performance of system, options, and ancillary equipment will vary depending on the system configuration.
  • Levels presented do not account for non-HP/Compaq installed hardware.
Features
Ambient Air Temperature
  • Operating: 50° to 95° degree Fahrenheit (10° to 35° degree Celsius) at sea level with an altitude de-rating of 1.0° degree Celsius per every 1000 ft (300 m) above sea level to a maximum of 8000 ft (2500 m), no direct sustained sunlight. Maximum rate of change is 77° degree Fahrenheit/Hr (25° degree Celsius/Hr). The upper limit may be limited by the type and number of options installed.
  • Storage: -22° to 140° degree Fahrenheit (-30° to 60° degree Celsius) – Maximum rate of change: 410° degree Fahrenheit/Hr (210° degree Celsius/Hr).
Humidity
  • Operating: 10% to 90% relative humidity (Rh), 86° degree Fahrenheit (30° degree Celsius) maximum wet bulb temperature, non-condensing
  • Storage: 10% to 95% relative humidity (Rh), 101.66° degree Fahrenheit (38.7° degree Celsius) maximum wet bulb temperature, non-condensing
Altitude
  • Operating: 0 to 10,000 feet (0 to 3048 meters) – This value may be limited by the type and number of options installed. Maximum allowable altitude change rate is 1,000 ft/min (304.8 m/min).
  • Non-Operating: 0 to 30,000 feet (0 to 9,144 meters) – Maximum allowable altitude change rate is 1200 ft/min (365.76 m/min).
Warranty information
On-site Warranty: One-year (1-1-1) limited warranty delivers one year of on-site, next business-day service for parts and labor and includes free telephone support 24 x 7. Global coverage ensures that any product purchased in one country and transferred to another non-restricted country will remain fully covered under the original warranty and service offering. One-year onsite and labor are not available in all countries
