Replacing the Printhead for HP Officejet 7000 Wide Format Printer Series
A printhead assembly consists of cartridges fitted into a printhead. If the printhead assembly sustains damage or is incompatible with the product, you might need to replace it. Replacement printhead assemblies are only available from HP Support or authorized service providers.
These steps apply to all countries/regions except the United States.
If HP replaces your printhead assembly under warranty, you receive a new printhead assembly, cleaning materials, and a full set of new ink cartridges with the replacement printhead.
If your printhead assembly is no longer under warranty, you can purchase a new one online.
  1. Go to the HP How to Buy website, and then click your country-language.
  2. A Buy HP page displays. Look for the HP Parts store on this page. The location of the HP Parts store varies depending on your region. Click HP Parts store.
  3. Under Find your part(s), type CN643A in the Search by part number text box. Follow the on-screen instructions to order the printhead assembly.
Replacing the printhead assembly
Follow these steps to replace the printhead assembly.
Wait until a new printhead assembly is available before removing the cartridges. Do not leave the cartridges outside of the product for longer than 30 minutes. Leaving the printhead and cartridges outside the product for long periods can damage both the product and the supplies.
Step one: Remove the old cartridges
  1. Press the Power button () to turn on the product, if it is not already on.
  2. Open the cartridge access door. The carriage moves to the center of the product. Wait until the carriage stops moving before proceeding.
    Illustration of how to open the cartridge access door
  3. To release an old cartridge, press in the tab on the front of the cartridge, and then remove it from the slot.
    Figure : Remove the cartridges
    Illustration of how to remove cartridges
  4. Repeat the previous step for each cartridge.
Step two: Remove the old printhead
  1. Lift the latch handle on the carriage until it stops.
    Figure : Lift the latch handle
    Illustration of lifting the latch handle
  2. Lift the printhead to remove it from the carriage.
    Figure : Remove the printhead
    Illustration of removing the printhead
Step three: Clean the electrical contacts inside the product
For successful printhead assembly replacement, it is important to get the electrical contacts inside the product as clean as possible. The replacement printhead assembly comes with pre-moistened wipes.
Figure : Pre-moistened wipes
Pre-moistened wipes
Use these wipes to clean the electrical contacts inside the product. Wipe from the top to the bottom of the electrical contacts, in one direction only. As the wipes become dirty, discard them and open new ones.
Figure : Clean the contacts
Illustration of cleaning the contacts
Do not wipe up and down or side to side, as doing so can damage the product.
Step four: Install the new printhead
  1. Remove the new printhead from its package.
    Figure : Remove the new printhead
    Do not touch the copper-colored electrical contacts. Do not scratch the electrical contacts on the product or any other surface.
    Figure : Do not touch the electrical contacts
  2. Hold the printhead upright with the colored shape icons on the top.
  3. Lower the printhead into the carriage.
    Make sure that the colored shapes on the sides of the printhead line up with the colored shapes on the carriage.
    Figure : Install the new printhead
  4. Carefully lower the latch handle.
    Figure : Lower the latch handle
Step five: Load plain paper
When you install the new cartridges in the next step, the product will print an alignment page. Before proceeding, use the following steps to load plain paper in the product.
  1. Lift the output tray.
    Figure : Lift the output tray
    illustration of lifting the output tray
  2. Slide the paper width guide to its outermost position.
  3. Insert the paper stack into the input tray with the short edge forward and print side down.
  4. Adjust the paper width guide so it rests against the stack of paper.
    Figure : Adjust the paper guide
    illustration of adjusting the paper width guide
  5. Lower the output tray.
Step six: Install the new cartridges
Do not reuse the old cartridges. They might damage the new printhead.
  1. Remove the plastic wrap on the cartridge by pulling the orange tab.
    Figure : Remove the cartridge plastic wrap
  2. Twist the orange cap counter-clockwise to snap it off the cartridge.
    Figure : Remove the orange cap
  3. With the cartridge contacts facing the printhead, slide each cartridge into its slot as indicated by the colored shape icons on the cartridge and on the printhead.
  4. Press down on each cartridge until it clicks into place.
    Figure : Slide the cartridge and press it into place
  5. Repeat this procedure for each cartridge.
    Figure : All cartridges installed
    All catridges installed
  6. Close the cartridge access door.
    Figure : Close the cartridge access door
    Illustration of how to close the cartridge access door
  7. Pull out the extension on the output tray.
    Figure : Pull out the tray extension
    illustration of pulling out the tray extension.
  8. The product goes through an initialization process, and then prints an alignment page. Discard or recycle the alignment page.
Step seven: Return failed parts to HP
If the new printhead assembly came with a post-paid mailing label and instructions to return the failed parts to HP, please do so. HP would like to analyze the parts in order to improve our products in the future.
If the new printhead assembly did not arrive with a post-paid return mailing label, you are done, and there is no need to continue troubleshooting.
  1. Place the old printhead into the plastic package that the new printhead arrived in.
    Figure : Put the old printhead into the package
  2. Peel off the lid sticker labeled B and seal the printhead package with it.
    Figure : Peel off the lid sticker
    Figure : Seal the package with the lid sticker
  3. Cap the old cartridges with the orange caps that came on the new cartridges.
    Figure : Cap the old cartridges
  4. Put the old parts and the form that came with the new parts into the box that the new parts came in. If possible, also include a printout that shows the issue with the old printhead.
    Figure : Put the old parts, form, and sample printout into the box
    Put the old parts, the form, and printout into the box
  5. Close the box, apply the post-paid mailing label, and then mail the box.
    Figure : Send the box back to HP
