    Looking for Site Help?
HP Pavilion Slimline PCs - Replacing the System Fan
This document pertains only to HP Slimline computers with the following computer case:
Image of the computer
Before you begin
  • You need a flathead screwdriver.
  • Remove the Pocket Media Drive, if it is present.
  • Turn off the computer, and then disconnect all cables. Disconnect the Ethernet or modem cable before disconnecting the power cord.
  warning:
Video overview
For best quality on dial-up connections, wait until the video has fully loaded before viewing.
Removing the system fan
Follow these steps to replace the system fan.
  warning:
Step 1
Remove the side panel.
For more information about removing the side panel, refer to the HP support document Opening the PC Case.
Image of removing the side panel
Step 2
Remove the front panel.
For more information about removing the front panel, refer to the HP support document Removing the Front Cover.
Image of swinging the front panel open
Step 3
Locate the system fan below the CD/DVD drive in its cage.
Note there are two fans in the computer. For this procedure, you remove the system fan (shown in the rectangle) located directly below the drive cage, not the processor fan to the left (shown with the circle and X).
Image of the system fan (shown in the rectangle) and the processor fan (shown with a circle and X)
Step 4
Remove the system fan screw.
Image of removing the system fan screw
Step 5
Push in the metal tab (1) above the fan and slide the fan down, tip out the top of the fan (2), and then lift the fan (3) partway out of the computer.
Image of releasing and removing the system fan partway out
of the computer
Step 6
Trace the system fan cable (1) from the fan through the cable bundle...
Image of the system fan cable at the fan
...to the motherboard (2), and then ...
Image of the system fan cable on the motherboard
...disconnect it (3). Write down where it was connected so you have that information when you install the new fan.
Image of disconnecting the system fan cable from the motherboard
Step 7
Clip the tie wrap that bundles the power cables and the system fan cable. Separate the fan cable, and then set the fan aside.
Image of cutting the cable tie
Replacing the system fan
Step 1
Connect the cable for the replacement system fan to the motherboard.
Image of connecting the system fan cable on the motherboard
Step 2
Replace the system fan by inserting the two lower hooks on the fan (1) into the slots in the computer, and then swinging the top of the fan (2) onto the computer.
Image of inserting the system fan
Step 3
Slide the system fan up, and then press the system fan until the metal tab locks it in place.
Image of the metal tab that locks the system fan in place
Step 4
Replace the system fan screw.
Image of replacing the system fan screw
Step 5
Bundle the power cables and the system fan cable with a new tie wrap to secure them.
Image of adding a cable tie to secure the power cables
Step 6
Replace the front panel.
For more information, refer to the HP support document Removing the Front Cover.
Image of pressing the front panel into place on the computer
Step 7
Replace the side panel.
For more information, refer to the HP support document Opening the PC Case.
Image of sliding the side panel toward the front of the computer
Country: Flag Bulgaria
