HP ProBook 4510s Notebook PC Product Specifications
Product description
The HP ProBook 4510s Notebook PC boasts a sleek design that packs an array of features normally reserved for more expensive notebooks.
Product features
Feature
  • Mobile Intel PM45 Express Chipset with ICHM9, 1066 MHz front side bus (models with discrete graphics)
  • Mobile Intel GM45 Express Chipset with ICHM9, 1066 MHz front side bus (models with integrated graphics)
  • Mobile Intel GL40 Express Chipset , 667 MHz front side bus (models with integrated graphics)
Processors
  • Intel Core 2 Duo Processor T9600 (2.8 GHz, 6 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Duo Processor T9400 (2.53 GHz, 6 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Duo Processor P8700 (2.53 GHz, 3 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Duo Processor P8600 (2.40 GHz, 3 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Duo Processor P7370 (2.0 GHz, 3 MB L2 cache, 1066 MHz FSB)*
  • Intel Core 2 Duo Processor T6570 (2.10 GHz, 2 MB L2 cache, 800 MHz FSB)*
  • Intel Core 2 Duo Processor T5870 (2.00 GHz, 2 MB L2 cache, 800 MHz FSB)*
  • Intel Celeron Dual-Core Processor T1700 (1.83 GHz, 1 MB L2 cache, 667 MHz FSB)*
  • Intel Celeron Dual-Core Processor T1600 (1.66 GHz, 1 MB L2 cache, 667 MHz FSB)*
  • Intel Celeron Processor 900 (2.20 GHz, 1 MB L2 cache, 800 MHz FSB)*
  • Intel Celeron Processor 585 (2.16 GHz, 1 MB L2 cache, 667 MHz FSB)*
Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
* Intel's numbering is not a measurement of higher performance.
Memory
Standard: 800 MHz DDR2 SDRAM; two slots supporting dual channel memory 1024 MB or 2048 MB.
Maximum: Upgradeable to 8192 MB with 4096 MB SODIMMs in slots 1 and 2.
Dual-channel: Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Graphics
Models with discrete graphics:
ATI Mobility Radeon HD 4330 discrete graphics with 512 MB dedicated video memory
  • up to 1024 MB HyperMemory* in units with Windows XP and 2 GB or more of system memory
  • up to 1280 MB HyperMemory* in units with Windows Vista Business and 2 GB or more of system memory
Models with integrated graphics and Mobile Intel GM45, GL40 Express chipset:
Mobile Intel Graphics Media Accelerator 4500MHD
  • up to 1024 MB of total graphics memory* in units with Windows XP and 2 GB or more of system memory
  • up to 1759 MB of total graphics memory* in units with Windows Vista Business and 4 GB or more of system memory
Microsoft DirectX 10.1 (discrete),10 (integrated) capable
* Indicates dedicated video memory and shared system memory.
Internal:
  • 15.6 inches diagonal LED-backlit HD anti-glare (1366 x 768 resolution).
  • 15.6 inches diagonal LED-backlit HD BrightView (1366 x 768 resolution).
  • 15.6 inches diagonal LED-backlit HD+ anti-glare WVA (1600 x 900 resolution).
External: Up to 32 bit per pixel color depth
  • VGA port supports resolutions up to 1600 x 1200 at 75 Hz, and lower resolutions at up to 100 Hz.
  • HDMI 1.3 port supports direct connection to high-definition displays with up to 1920 x 1080 resolution and 7-channel audio with one convenient cable.
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Keyboard
The HP spill-resistant keyboard is designed using a Mylar film that minimizes the risk of damage to sensitive components underneath.
The 101/102-key compatible keyboard features an industry standard, full-pitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. US and International key layouts are available. Other features include a full numeric keypad, hotkeys for instant access to power conservation, brightness, and other features, 19.05 x 19.05 mm key pitch (center-to-center spacing), 3.0 mm stroke, and comfort-dished keycaps.
Pointing device
Touchpad with scroll zone, two pick buttons.
Storage
Internal Storage Device : 160/250/320/500 GB 5400 rpm, 160/250 GB 7200 rpm SMART SATA II Hard Drive.
HP 3D DriveGuard : The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Fixed optical drives:
  • Blu-ray ROM DVD+/-RW SuperMulti DL LightScribe Drive
  • DVD+/-RW SuperMulti DL LightScribe Drive
  • DVD-ROM Drive
Expansion card slots
ExpressCard/34 slot Supports ExpressCard/34 (34 mm x 75 mm x 5 mm) card sizes
Media Card Reader Supports SD (Secure Digital), MMC (MultiMedia Card), Memory Stick, Memory Stick Pro, Memory Stick Duo*, xD-Picture card
* Memory Stick Duo Adapters are required and sold separately. Inserting a Memory Stick Duo Card directly into your notebook could damage the memory card and/or notebook.
Power Supply
External 65 W Smart AC adapter
External 90 W Smart AC adapter (discrete graphics only)
Battery
Primary battery:
  • 6-cell (47 WHr) Li-Ion battery
  • 8-cell (63 WHr) Li-Ion battery
Communications
Features
HP un2400 EV-DO/HSPA Mobile Broadband Module
Integrated WWAN module with Gobi global mobile Internet technology that provides worldwide connection to both CDMA (EVDO) and UMTS (HSPA) wireless networks.
Two 850/900/1800/1900/2100 MHz antennas integrated in the top of the display panel support current and future WWAN technologies.
All 802.11 integrated wireless LAN options
  • Wi-Fi certified
  • Wired Equivalent Privacy (WEP) support up to 128-bit keys
  • Wi-Fi Protected Access (WPA) and WPA2 support
  • 802.1x authentication support, including EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, and LEAP
  • Advanced Encryption Standard (AES) support
  • Dual antennas integrated in the display enclosure
Intel WiFi Link 5100
Integrated support for 802.11a, b, g, and n draft 2.0 Cisco Compatible Extensions support Up to 450 mbps data rate.
Integrated support for 802.11 a, b and g Cisco Compatible Extensions support Up to 54 mbps data rate.
Broadcom 4322AGN 802.11a/b/g/draft-n Wi-Fi Adapter
Integrated support for 802.11a, b, g, and n draft 2.0 Cisco Compatible Extensions support Up to 300 mbps data rate.
Broadcom 4312G 802.11b/g WiFi Adapte
802.11b/g WiFi Adapter Integrated support for 802.11 b and g Cisco Compatible Extensions support Up to 54 mbps data rate.
HP Integrated Module with Bluetooth Wireless Technology
Bluetooth Specification v2.0 compliant Works with a wide range of Bluetooth devices.
Audio/Visual
Features
Audio
  • High Definition Audio support
  • Integrated microphone
  • Integrated stereo speakers
  • Stereo headphone/line out
  • Stereo microphone in
Visual
Optional 2 MP webcam:
  • Supports videoconferencing and still image capture
  • Improved quality for video streaming and still image capture (1600x1200 resolution)
  • Up to 30 frames/sec
  • Fixed focus lens
  • 16-bit true color (camera sensor up to UXGA resolution)
Physical specifications
Features
Dimensions (HxWxD)
  • 1.24 in (at front) x 14.6 in x 9.83 in
  • 31.5 mm (at front) x 371.8 mm x 249.6 mm
Starting at 5.7 lb (2.59 kg)
Stand-Alone Power Requirements (AC Power)
  • Normal Operating Voltage 18.5 V.
  • Average Operating Power: 12.8 W.
  • Max Operating power: < 90 W or < 65 W.
Temperature
Operating: 32 degree to 95 degree F (0 degree to 35 degree C).
41 degree to 95 degree F (5 degree to 35 degree C) (writing optical).
Non-operating: –4 degree to 140 degree F (–20 degree to 60 degree C).
Relative Humidity
Operating: 10% to 90%, non-condensing.
Non-operating: 5% to 95%, 101.6 degree F (38.7 degree C) maximum wet bulb temperature.
Altitude (unpressurized)
Operating: -50 to 10,000 ft (-15.24 to 3,048 m).
Non-operating : 50 to 40,000 ft (-15.24 to 12,192 m).
Security
  • HP ProtectTools Security Manager
  • Easy Setup Wizard
  • One Step Login, Enhanced Pre-Boot Security
  • HP SpareKey, Disk Sanitizer
  • Configuration Control Hardware, Memory Change Alert
  • Ownership Tag
  • Setup Password
  • Power-On Password
  • HP 3D DriveGuard (Windows models only)
  • Kensington Lock Slot
  • Support for Computrace / LoJack for Laptops (must be purchased separately)
  • HP Privacy Filter (must be purchased separately)
Software/OS
Feature
Operating System
  • Genuine Windows Vista Business 64 bit
  • SuSE Linux
  • Red Flag Linux (PRC only)
  • Genuine Windows Vista Business with downgrade to Windows XP Professional custom installed
Preinstalled software with Windows Vista:
  • HP Recovery Manager
  • HP Help and Support Center
  • HP QuickLaunch Buttons Software
  • HP QuickLook 2
  • HP Connection Manager
  • HP Wireless Assistant
  • HP 3D DriveGuard, Microsoft Office Ready with 60-day Office Professional 2007 Trial Edition (select models)
  • PDF Complete SE
  • Intervideo WinDVD - DVD Player, Roxio Creator Business (for optional DVD+/-RW and DVD/CDRW drives)
  • McAfee Total Protection*
  • Synaptics Touchpad Driver
  • Microsoft Windows Live Messenger (select models)
  • Webcam Software (with optional 2 MP webcam)
Additional software available from the web: HP SoftPaq Download Manager
* 60 day trial period for McAfee Total Protection for Small Business software. Internet access required to receive updates. First update included. Subscription required for updates thereafter.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
