HP Deskjet D5560 and D5568 Printers - Setting up a New Printer
This document describes how to set up the product hardware and install the software.
Setting up a new printer
Follow these steps to set up the product hardware and install the software.
Do not connect the USB cable until these steps prompt you to do so.
Step one: Verify the box contents
Make sure the box contains the following items along with the new HP product:
Item
Example
Cartridges
Illustration of cartridges
Software CD
Illustration of the software CD
USB cable
Illustration of the USB cable
Power cord
Illustration of the power cord
Power supply
Illustration of the power supply
Step two: Unpack the printer
  1. Lift the product out of its box.
  2. Remove all tape from the paper tray, and then open the cartridge door.
    Figure : Open the cartridge door
    Illustration of opening the cartridge door
  3. Remove the packing material from inside the front access door.
  4. Close the cartridge door.
    Figure : Close the cartridge door
    Illustration of closing the front access door.
Step three: Connect the power
Do not connect the USB cable at this stage.
Figure : Do not connect the USB cable yet
Illustration: Do not connect the USB cable yet
  1. Turn the product to access its rear side.
  2. Plug the power cord into the rear of the product.
    Figure : Connect the power cord to the rear of the product
    Illustration of connecting the power cord to the rear of the product.
  3. Connect the power cord to the power supply.
    Figure : Connect the power cord to the power supply
    Illustration of connecting the power cord to the power supply.
  4. Plug the other end of the power cord into an electrical outlet.
    Figure : Connect the power cord to the electrical outlet
    Illustration of connecting the power cord to the electrical outlet.
  5. Press the Power button () to turn on the product.
Step four: Load plain paper
  1. Open the paper tray.
    Figure : Open the input paper tray
    Illustration of opening the input tray/output bin.
  2. Pull out the paper tray extender.
    Figure : Pull out the paper tray extender
    Illustration of pulling out the paper tray extender
  3. Lift up the paper stop at the end of the paper tray extender.
    Figure : Lift up the paper stop
    Illustration of lifting up the paper stop.
  4. Slide the paper-width guide to its outermost position.
    Figure : Slide the paper guide out
    Illustration of sliding the paper guide out.
  5. Load the stack of paper into the paper tray with the short edge forward and the print side down. Slide the paper under the output platform, and push it forward until it stops.
    Figure : Load paper
    Illustration of loading paper in the paper tray.
  6. Slide the paper guide inward until it rests against the paper.
    Figure : Slide the paper guide inward
    Illustration of sliding the paper guide inward.
Step five: Install the cartridges
  1. Open the cartridge door.
  2. Wait until the carriage moves to the center of the product and is idle and silent.
  3. Remove one of the new cartridges from its packaging, and then pull the pink pull-tab to remove the protective tape from the nozzles.
    Figure : Remove the protective tape
    Illustration of removing the protective tape
    Do not touch the cartridge contacts or ink nozzles
    Figure : Do not touch the contacts
    Illustration: Do not touch the cartridge contacts
  4. Hold the cartridge by its sides.
    Figure : Hold the cartridge by its sides
    Illustration of holding the cartridge
  5. Insert the cartridge into its designated slot. The black parallelogram icon () designates the slot for the black cartridge, and the magenta half circle icon () designates the slot for the color cartridge.
    Figure : Insert cartridge
    Illustrating of inserting the cartridge
    Figure : Cartridge rests at upward angle
    Illustration of cartridge resting at upward angle
  6. Press the cartridge in to snap it into place.
    Figure : Snap cartridge into place
    Illustration of snapping the cartridge into place
  7. Repeat these steps to replace the other cartridge.
  8. Close the cartridge door.
    When you close the cartridge door, a cartridge alignment process begins automatically within 90 seconds.
    • If the alignment process does begin automatically, skip the next step, and continue to the following step to install the software.
    • If the alignment process does not begin automatically, continue to the next step to align the cartridges manually.
Step six: Align the cartridges
  1. Open HP Solution Center using one of the following methods.
    • Windows Vista: On the Windows taskbar, click the Windows icon (), click All Programs, point to HP, and then click HP Solution Center.
    • Windows XP: On the Windows taskbar, click Start, click All Programs, point to HP, and then click HP Solution Center.
  2. Click Settings, and then click Printer Toolbox. The Printer Toolbox dialog box opens.
  3. Click Align the Print Cartridges.
  4. Click Align, and then follow the on-screen instructions.
    The product prints a test page, aligns the ink cartridges, and calibrates the product.
Step seven: Install the software
Use one of the following options to install the software.
If you do not have the software CD, see Option three at the end of this section to download and install the software.
Option one: Install the software from the CD on a Windows computer
  1. Insert the software CD into the CD drive of the computer.
    Do not connect the USB cable yet.
    Figure : Insert the software CD, but do not connect the USB cable
    Illustration of inserting the software CD
  2. Follow the on-screen instructions until the software prompts you to connect the USB cable.
    Figure : Windows on-screen installation instructions
    Illustration of the software installation screens in Windows
  3. When prompted, connect the USB cable to the rear of the product and to the computer.
    Figure : Connect the USB cable
    Illustration of connecting the USB cable to a Windows computer
  4. Continue to follow the on-screen instructions to complete the installation.
Option two: Install the software from a CD on a Macintosh computer
  1. Connect the USB cable to the rear of the product and to the computer.
    Illustration of connecting the USB cable to a Macintosh computer
  2. Insert the CD into the CD drive on the computer.
    Figure : Insert the CD
    Illustration of inseting the CD in a Macintosh computer
  3. Follow the on-screen instructions to complete the installation.
    Figure : Macintosh on-screen installation instructions
    Illustration of on-screen installation instructions in Macintosh
