HP Designjet T1120 MFP Product Series - Color Matching Results are not Optimal
The steps below can help remedy color matching problems with your copies.
  1. Try using the Color Poster original type. This is a neutral original type that does not apply special image processing that could affect color matching.
  2. Control your Original Type settings in the Copy > Original Type dialog. Press the More Button to view and adjust the specific settings relevant to the Original Type.
  3. If the above does not help, press Options > Printer Options > Update Profile to recreate your current media profile and thus ensure it contains optimal color matching data for the current media and printer conditions.
  4. If the above does not help, check that the scanner is clean and recently calibrated. If in doubt, clean the scanning area and calibrate the scanner. Repeat step 2 to update the media profile data with the changed scanner calibration conditions.
