HP Designjet T1120 MFP Product Series - Printer Options Dialog
Printer Options
The Printer Options dialog displays information about your current printer and media profile.
Figure : Printer Options dialog
Status: ...of the printer. Examples: waiting, printing, low on ink, paper jam...
Current Media: This shows the media setting on the printer. The media setting on the printer must correspond with the actual media loaded.
Media width: This shows the media width setting on the printer. The media width setting on the printer must correspond with the actual media loaded.
Media Profile: The media profile loaded for color matching. The media profile value will be one of the following:
  • “Default” – the media profile for the current media was supplied with the program and has not been updated. If initial color results with this profile are not satisfactory, you should update the profile. Press the Update Profile button to start the wizard.
  • “Created” dd-mm-yyyy – the current media profile has been created/ updated on the date specified. If your initial color results with this profile are not satisfactory, you should update the profile. Press the Update Profile button to start the wizard.
  • “Not Created” – the system has not found a media profile for the current media. You need to create a media profile. Press the Create Profile button to start the wizard.
