To look up RoHS-compliant information in PartSurfer, use the component’s option part number or the sales order number for a system in which the component is used (available in the QuickSpecs or Standard Models page).
- ${title}
- ${title}
- ${title}
- ${title}
HP Z400 Workstation - Spare Parts
New model specific parts lists
System unit
Part Description
Spare Part Number
Front bezel plastic blank cover - For 5.25 in access bay
536306-001
Front bezel assembly
536662-001
Chassis access panel
536663-001
Power supply 475 W - Rated at 85+ efficiency - With Built-In Self-Test (BIST) mode
480720-001
Power supply 600 W - Rated at 80+ efficiency - With Built-In Self-Test (BIST) mode
626409-001
Standard and optional boards
Part Description
Spare Part Number
System board (motherboard) - Intel Tylersburg-WS 2S platform, 1333 MHz front side bus
461438-001
System board (motherboard) - Intel Tylersburg-C2 1S/DDR3, 1333 MHz front side bus, six DIMM memory slots, and one IEEE-1394a (Firewire) port
586968-001
Processors:
Intel Nehalem 1S Xeon Dual Core processor W3503 - 2.4 GHz (Bloomfield, 1066 MHz front side bus, 4MB Level-3 cache, and 130 W TDP)
538618-001
Intel Nehalem 1S Xeon Dual Core processor W3505 - 2.53 GHz (Bloomfield, 1066 MHz front side bus, 4MB Level-3 cache, and 130 W TDP)
538619-001
Intel Nehalem EP Xeon Quad-Core processor W3520 - 2.66 GHz (Bloomfield, 1333 MHz front side bus, 8MB Level-3 cache, and 130 W TDP)
538620-001
Intel Nehalem EP Xeon Quad Core processor W3540 - 2.93 GHz (Bloomfield, 1066 MHz front side bus, 8MB Level-3 cache, and 130 W TDP)
538621-001
Intel Nehalem EP Xeon Quad-Core processor W3550 - 3.066GHz (Bloomfield, 1366MHz front side bus, 8MB Level-3 cache, socket LGA-1366, and 130W TDP)
577061-001
Intel Nehalem EP Xeon Quad Core processor W3570 - 3.2 GHz (Bloomfield, 1133 MHz front side bus, 8MB Level-3 cache, and 130 W TDP)
538622-001
Intel Nehalem EP Xeon Quad Core processor W3565 - 3.2 GHz (Bloomfield, 1133 MHz front side bus, 8MB Level-3 cache, and 130 W TDP)
592501-001
Intel Nehalem EP Xeon Quad-Core processor W3670 - 3.2 GHz (Bloomfield, 1333 MHz front side bus, 12MB Level-3 cache, and 130 W TDP)
626581-001
Memory modules:
2GB DDR3-1333, PC3-10600E (ECC), 10.66GB/s bandwidth, CL=9 memory module
536887-001
1GB DDR3-1333, PC3-10600E (ECC), 10.66GB/s bandwidth, CL=9 memory module
536888-001
4GB DDR3-1333, PC3-10600E (ECC), 10.66GB/s bandwidth, CL=9 memory module
537755-001
Mass storage devices
Part Description
Spare Part Number
1.44MB 3.5 in floppy drive - With bezel
506465-001
16X DVD/RW SATA SuperMulti dual layer optical drive - With LightScribe
506462-001
16x DVD/RW SATA DVD-ROM optical drive
506464-001
DVD 6X RW SMD LScribe SATA JB
536540-001
1TB SATA hard drive - 7,200 RPM, 3.5 in form factor, and NCQ (Native Command Queuing) technology
508027-001
146GB Serial Attached SCSI (SAS) hard drive - 15,000 RPM
405430-001
160GB SATA SQ hard drive - 7,200 RPM, 3.5-inch form factor - With Native Command Queuing (NCQ) technology
453139-001
160GB SATA SQ hard drive - 10,000 RPM, 3.5 in form factor, 1.0 inch high
508029-001
250GB SATA SQ hard drive - 7200 RPM, 3.5 in form factor, 8MB cache
508028-001
HP 300GB Serial Attached SCSI (SAS) hard drive - 15,000 RPM, 3.5 in form factor, 1.0 inch high
413647-001
320GB SATA hard drive - 7200 RPM, 3.5 in form factor, and NCQ (Native Command Queuing) technology
508026-001
450GB hot-plug Serial Attached SCSI (SAS) hard drive - 15,000 RPM, 3.5 in form factor
495608-001
500GB SATA SQ hard drive - 7,200 rpm in 3.5-inch form factor - With Native Command Queuing (NCQ) technology
460579-001
300GB SATA SQ hard drive - 10,000 RPM, 3.5 in form factor, 1.0 in high
502599-001
Electronic parts
Part Description
Spare Part Number
Cable (Interface)
SATA hard drive interface cable
392308-001
Power LED thermal sensor cable
536304-001
Front user interface (UI) cable
536660-001
SATA hard drive interface cable - Has 7-pin to 7-pin right angled connector, 45.72 cm (18 in) long
393958-001
HP DisplayPort (DP) to DVI-D adapter and VGA connector cable
484156-001
Graphics card power adapter interface cable, 8-pin
512318-001
External cable - For PCIe IEEE 1394b Firewire card
447004-001
eSATA connections and PCI bulkhead
465341-001
SCSI LED cable assembly - two-pin (F) to four-pin (F), 22.9 cm (9 in) long - For showing hard drive activity
415949-001
Floppy diskette drive cable
415947-001
484156-001
512318-001
SAS LED cable, 2-pin to 2-pin, 16-inches long
462774-001
Cable kit - For internal miniSAS components
446042-001
SATA drive dual device cable - 7-pin S-ATA to 7-pin right angle S-ATA, 17 inches long
453317-001
Interface cable - For slot load Super-Multi optical drive
536307-001
Fan
Chassis cooling fan - Size 92 x 25 mm
434645-001
Liquid cooling module fan assembly - With support bracket
577421-001
Cooling fan kit - With front guard and fan
619579-001
Mouse
USB two-button scrolling optical mouse (Carbonite Black with Silver buttons) - Has 1.8 m (6.0 ft) long cable with USB type (A) connector
390938-001
PC Board (Graphics)
PCIe ATI FirePro V7750 Workstation graphics accelerator card - With 1GB 128 bit GDDR3 memory and High Dynamic Range (HDR) rendering - DirectX 10.1 and OpenGL 2.0 supported
519293-001
PCIe 3D NVIDIA Quadro FX 4800 graphics card - With 1GB 256-bit GDDR3 memory, 602 MHz core clock, and 150 W TDP
536796-001
492188-001
PCIe 3D NVIDIA Quadro FX 5800 graphics card - With 2GB 512-bit GDDR3 memory, 650 MHz core clock, and 189 W TDP (Gen 2.0)
536797-001
PCIe ATI FirePro V3700 Workstation graphics accelerator card - With 256MB 64-bit GDDR3 memory and High Dynamic Range (HDR) rendering - DirectX 10.1 and OpenGL 2.0 supported
519291-001
PCIe ATI FirePro V5700 Workstation graphics accelerator card - With 512MB 128-bit GDDR3 memory and High Dynamic Range (HDR) rendering - DirectX 10.1 and OpenGL 2.0 supported
519292-001
PCIe ATI FirePro V7750 Workstation graphics accelerator card - With 1GB 128-bit GDDR3 memory and High Dynamic Range (HDR) rendering - DirectX 10.1 and OpenGL 2.0 supported
519293-001
PCIe 3D NVIDIA Quadro FX 380 graphics card - With 256MB 128-bit GDDR3 memory, 34 W TDP
519294-001
PCIe 3D NVIDIA Quadro FX 580 graphics card - With 512MB 128-bit GDDR3 memory, 40 W TDP
519295-001
PCIe 3D NVIDIA Quadro FX 1800 graphics card - With 768MB 192-bit memory, 59 W TDP
519296-001
PCIe 3D NVIDIA Quadro FX 3800 graphics card - With 1GB 192-bit memory, 59 W TDP
519297-001
PCIe 3D NVIDIA Quadro NVS 295 graphics card - With 256MB 64-bit DDR2 memory, 21 W TDP. Low profile
519298-001
DVI-I to VGA adapter - From a (M) DVI-I connector to a (F) 15-pin VGA connector - For connecting a VGA monitor to a DVI-I port on the graphics board
202997-001
NVidia Quadro nvs450 512MB PCI-E HF graphics card
683868-001
NVIDIA Quadro 600 PCIe graphics card - With 1GB GDDR3 GPU memory, maximum display resolution digital @ 60Hz 2560x1600 pixels
671135-001
NVIDIA Quadro 2000 PCIe 2.0 x16 graphics card - With 1GB GDDR5 SDRAM memory
671136-001
NVIDIA Quadro 4000 PCIe 2.0 x16 graphics card - With 2GB GDDR5 SDRAM memory
671137-001
NVIDIA Quadro 5000 PCIe graphics card - With 2.5GB GDDR5 GPU memory, max resolution 2560x1600, one Dual Link DVI-I and two DisplayPorts
671138-001
PC board (Audio)
PCIe Sound Blaster X-Fi Xtreme Gaming sound card
493346-001
PC board (Interface)
202997-001
PCIe IEEE 1394 firewire card, full height
515182-001
PCIe IEEE 1394b Firewire interface card
508927-001
PCI Express x4 (4-port) Serial Attached SCSI (SAS) and Serial ATA RAID interface card
510359-001
Broadcom NetXtreme Gigabit Ethernet Plus network adapter card - 10BaseT/100Base-TX/1000Base-T, 1Gbps data transfer rate, PCIe x1, one RJ-45 connector
488293-001
Miscellaneous parts
Part Description
Spare Part Number
Miscellaneous hardware kit - Contains Silver matte textured chassis foot, IEEE 1394 cable clip, and hard drive isolation grommets
536661-001
USB powered flat speakers
466618-001
Floppy drive carrier assembly - For inserting floppy drive into optical disk drive bay
537757-001
Serial Attached SCSI (SAS) to Serial ATA (SATA) hard drive adapter
434926-001
Hard drive carrier assembly - For inserting 3.5-inch drive into optical disk drive bay
570576-001
USB media card reader - Contains 22-in-1 media device support and 3.5-inch form factor
480032-001
HP PS/2 optical scrolling mouse (Carbon Black) - Two button mouse with scrolling wheel - Has 1.75 m (69 in) long cable with 6-pin mini-DIN connector
417966-001
HP USB Laser scroll mouse - Has 1.8 m (72 in) long USB cable
459821-001
USB 3-button mouse (Carbon Black) - Has 2.9 m (10 ft) cable with type (A) USB connector
389026-001
390938-001
3-button, USB Optical, JB
573077-001
3-button, USB Optical, JB, 2.9 m
573078-001
Wheel USB Optical, JB, 2.9 m
573259-001
Heatsink Liquid Cooling Single CPU
534044-001
Heatsink, CPU Mainstream
535586-001
Heat sink assembly - For high performance CPU
538042-001
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
