HP Z600 Workstation Product Specifications
The HP Z600
Product features
Feature
Intel 5520
Super I/O Controller
SMSC SCH5327, Rev B
Processor Socket
Single LGA1366
Memory Modes
NUMA (Non-Uniform Memory Architecture), Memory Node Interleave
Memory Speed Supported
800, 1066, & 1333 MHz
Processors
  • Intel Xeon Processor X5570 QC 2.93 GHz, 95W, 8M cache, 6.40GT/s QPI, DDR3 1333 MHz, HT, Turbo
  • Intel Xeon Processor X5560 QC 2.80 GHz, 95W, 8M cache, 6.40GT/s QPI, DDR3 1333 MHz, HT, Turbo
  • Intel Xeon Processor X5550 QC 2.66 GHz, 95W, 8M cache, 6.40GT/s QPI, DDR3 1333 MHz, HT, Turbo
  • Intel Xeon Processor E5540 QC 2.53 GHz, 80W, 8M cache, 5.86GT/s QPI, DDR3 1066 MHz, HT, Turbo
  • Intel Xeon Processor E5530 QC 2.40 GHz, 80W, 8M cache, 5.86GT/s QPI, DDR3 1066 MHz, HT, Turbo
  • Intel Xeon Processor E5520 QC 2.26 GHz, 80W, 8M cache, 5.86GT/s QPI, DDR3 1066 MHz, HT, Turbo
  • Intel Xeon Processor E5506 QC 2.13 GHz, 80W, 4M cache, 4.80GT/s QPI, DDR3 800 MHz
  • Intel Xeon Processor E5504 QC 2.00 GHz, 80W, 4M cache, 4.80GT/s QPI, DDR3 800 MHz
Memory
CTO
PC3-10600 DDR3-1333 ECC Unbuffered DIMMs CTO:
  • 1 GB (1x1GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
  • 2 GB (2x1 GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
  • 3 GB (3x1 GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
  • 4 GB (2x2 GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
  • 6 GB (3x2 GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
  • 8 GB (2x4 GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
  • 12 GB (3x4 GB) DDR3-1333 ECC Unbuffered RAM 1-CPU
  • 2 GB (2x1 GB) DDR3-1333 ECC Unbuffered RAM 2-CPU
  • 4 GB (4x1 GB) DDR3-1333 ECC Unbuffered RAM 2-CPU
  • 4 GB (2x2 GB) DDR3-1333 ECC Unbuffered RAM 2-CPU
  • 6 GB (6x1 GB) DDR3-1333 ECC Unbuffered RAM 2-CPU
  • 8 GB (4x2 GB) DDR3-1333 ECC Unbuffered RAM 2-CPU
  • 8 GB (2x4 GB) DDR3-1333 ECC Unbuffered RAM 2-CPU
  • 12 GB (6x2 GB) DDR3-1333 ECC Unbuffered RAM 2-CPU
  • 16 GB (4x4 GB) DDR3-1333 ECC Unbuffered RAM 2-CPU
  • 24 GB (6x4 GB) DDR3-1333 ECC Unbuffered RAM 2-CPU
The Z600 has a three-channel memory architecture. Three channels are associated with each processor. For optimal performance, populate a DIMM in each channel.
AMO
PC3-10600 DDR3-1333 ECC Unbuffered DIMMs AMO
  • 1 GB (1x1 GB) DDR3-1333 ECC Unbuffered RAM
  • 2 GB (1x2 GB) DDR3-1333 ECC Unbuffered RAM
  • 4 GB (1x4 GB) DDR3-1333 ECC Unbuffered RAM
Although all of these memory configurations incorporate 1333 MHz memory modules, the speed at which they operate is dependent upon the processor.
Graphics
Professional 2D:
  • NVIDIA Quadro NVS 295 256 MB PCIe Graphics Card
  • NVIDIA Quadro NVS 450 512 MB PCIe Graphics Card
  • NVIDIA Quadro NVS 290 256 MB PCIe Graphics Card with 'DMS-59 to Dual DVI cable' included - for Workstations
Entry 3D:
  • NVIDIA Quadro FX 380 256 MB PCIe Graphics Card
  • ATI FirePro V3700 256 MB PCIe Graphics Card
  • NVIDIA Quadro FX 580 512 MB PCIe Graphics Card
Mid-range 3D:
  • NVIDIA Quadro FX 1800 768 MB PCIe Graphics Card
  • ATI FirePro V5700 512 MB PCIe Graphics Card
High End 3D:
  • NVIDIA Quadro FX 3800 1.0 GB PCIe Graphics Card (NOT AVAILABLE UNTIL JUNE 2009)
  • ATI FirePro V7750 1.0GB PCIe Graphics Card
  • NVIDIA Quadro FX 4800 1.5 GB PCIe Graphics Card
  • NVIDIA Quadro CX - The Accelerator for Creative Suite 4
Monitors
  • HP LP3065 30 inches Widescreen LCD Monitor
  • HP DreamColor LP2480zx Professional Display
  • HP LP2475w 24 inches Widescreen LCD Monitor
  • HP LP2275w 22 inches Widescreen LCD Monitor
  • HP LP1965 19 inches LCD Monitor
Input Devices
  • HP PS/2 Standard Keyboard
  • HP USB Standard Keyboard
  • HP PS/2 Optical Scroll Mouse
  • HP USB 2-Button Optical Scroll Mouse
  • HP USB Laser Mouse
  • HP USB Optical 3-Button Mouse
  • HP USB Smart Card Keyboard
  • HP 2.4 GHz Wireless Keyboard & Mouse
  • HP USB Optical 3-Button 2.9M OEM Mouse
  • HP SpaceExplorer 3D USB Controller
  • HP SpacePilot 3D USB Intelligent Controller
Power Supply
650 W 85% (80PLUS Bronze) Efficient wide-ranging, active Power Factor Correction, with tool-free & cable-free connection.
Communications
Features
Integrated Broadcom 5764 PCIe LOM Controller
Connector: RJ45
Broadcom (5761) NetXtreme Gigabit Ethernet Plus NIC
Connector: RJ45
Controller: Broadcom 5761 PCI-Express LAN Controller
Memory: 8 MB NVRAM serial Flash
Operating System Driver Support: Windows Vista 32-bit SP1, Windows Vista x64 SP1, Windows XP 32 bit professional, Windows XP x64 .
Intel Gigabit CT Desktop NIC
Connector: RJ45
Controller: Intel WG82574L Gigabit Ethernet Controller
Memory: Integrated Dual 48K configurable transmit receive FIFO Buffers
Operating System Driver Support: Windows Vista Business 64, Windows Vista Business 32, Windows XP Professional, Windows XP x64. Red Hat Enterprise Linux 4, Red Hat Enterprise Linux 5.
Multimedia
Features
Multimedia and Audio Devices
  • Integrated Intel/Realtek HD ALC262 Audio
  • HP Thin USB Powered Speakers
  • Creative X-Fi Titanium PCIe Audio Card
Physical specifications
Features
Chassis Dimensions (W x D x H)
17.5 x 6.5 x 17.3 inches (44.51 x 16.53 x 44 cm)
Minimum config – 33.0 lb (15.0 kg)
Typical config – 37.4 lb (16.9 kg)
Maximum config – 43.3 lb (19.6 kg)
(Maximum shipping weight – 52.0 lb / 23.6 kg)
Front I/O
3 USB 2.0, 1 Headphone Out, 1 Microphone In, and 1 IEEE 1394a (For front 1394a port to function, optional 1394 card must be installed.)
Rear I/O
  • 6 USB 2.0
  • 1 RJ-45 to integrated Gigabit LAN
  • 2 legacy PS/2
  • 1 Audio Line In, 1 Audio Line Out, 1 Microphone In; audio ports can be retasked to function as line in, line out, microphone, or headphone.
  • Serial supported with optional rear bulkhead adapter.
Internal USB
3 USB 2.0 headers
Temperature
Operating: 40 degree to 95 degree F (5 degree to 35 degree C)
Non-operating: –40 degree to 140 degree F (–40 degree to 60 degree C)
Relative Humidity
Operating: 8% to 85%
Non-operating: 8% to 90%
Maximum Altitude (unpressurized)
Operating: 10,000 feet; 3,000 m
Non-operating: 30,000 feet; 9,100 m
Security
  • Security Cable with Kensington Lock
  • HP Solenoid Hood Lock & Hood Sensor
  • HP (CMT) Solenoid Lock
  • HP xw4/Z4 Depth Adjustable Fixed Rail Rack Kit
Software overview
Feature
Operating System
  • Genuine Windows Vista Business 32 bit
  • Genuine Windows Vista Business 64 bit
  • Genuine Windows Vista Business 32 bit with downgrade to Windows XP Professional 32 bit custom installed
  • Genuine Windows Vista Business 64 bit with downgrade to Windows XP Professional x64 custom installed
  • HP Linux Installer Kit
