Adding or Replacing a Hard Drive in Compaq Presario CQ5000 Series PCs
This document pertains only to HP and Compaq desktop computers with the following computer cases (your case might be slightly different).
Before you begin
  • Turn off the computer, disconnect all cables, and transfer the computer to a clear, flat, stable work surface over a noncarpeted floor.
  • HP strongly recommends the use of an antistatic wrist strap and a conductive foam pad when working on the computer.
  • To add an additional SATA hard disk drive, an additional SATA data cable is required.
  warning:
If you are adding an additional hard drive
When adding a hard drive, it is important to identify the connectors on the motherboard.
The hard drive connectors on the motherboard must match the type of hard drive you wish to connect. If your motherboard has SATA data connectors and one is not in use, you can attach an additional SATA hard drive. If your motherboard has an IDE connector available, you can attach an IDE hard drive.
If you want to install an IDE hard drive to a motherboard that has only SATA data connectors, a third-party adapter is necessary.
    Figure : Motherboard with IDE and SATA data connectors
    Motherboard with SATA and IDE connectors
  1. IDE connectors
  2. SATA data connectors
    Figure : Example of SATA connections
    Hard drives with SATA cables connected
  1. Power cable
  2. SATA data cable
    Figure : Example of an IDE connection
    Hard drive with IDE cables connected
  1. IDE ribbon cable
  2. Power cable
Video overview
View the following video before using the steps in this document.
Find which steps to use
If you are replacing the primary hard drive in the 3.5" external drive bay, use sections Removing the hard drive from the external drive bay and Replacing the hard drive in the external drive bay
If you want to add a second hard drive, use section Add or replace a secondary drive.
If you are replacing the secondary hard drive, use sections Removing a secondary hard drive and Add or replace a secondary drive.
Removing the hard disk drive from the 3.5" external drive bay
Use the steps in this section to remove a hard drive so that an empty bay can be used to install a new drive.
  warning:
Step 1
With all cables disconnected from the computer, remove the right side panel and the front cover.
If you need assistance, see the HP support documents Opening the Computer Case and Removing the Front Cover.
Removing the side panel
Removing the front cover
Step 2
Find the disk drive at the front of the computer.
Hard disk drive in the front of the computer
Step 3
Disconnect the power and data connectors from the back of the hard disk drive.
Disk drive power and data connectors
Your hard drive has serial ATA power and data connectors that have a latch that must be squeezed to remove the connector.
Power connector tab
Step 4
Remove the screws that hold the hard disk drive to the computer.
Disk drive screws
Step 5
Pull the disk drive through the front of the computer.
Removing the hard disk drive from the front of the computer
Replacing a hard disk drive into the external drive bay
Follow these steps to replace a hard disk drive into the 3.5-inch bay on front of your computer.
Step 1
Push the drive into the bay all the way through the front of the computer.
Hard disk drive being put into computer
Step 2
Align the screw holes on the hard disk drive bay with the screw holes in the computer marked HDD.
Aligning hard drive screw holes
Step 3
Replace the screws.
Hard drive screws being replaced
Step 4
Connect the power and data cables to the drive.
Power and data connectors
Step 5
Replace the front cover and the side panel, and then reconnect the cables and power cord.
MBR or NTFS partitions are limited to 2 TB (without using dynamic disks and volume sets). If you are installing a hard drive that is 2 TB or greater, HP recommends formatting the drive using GPT partitions.
For information about replacing the front cover, see the HP support document Removing the Front Cover.
For information on replacing the side panel, see the HP support document Opening the Computer Case.
Replacing the front cover
Replacing the side panel
Removing a secondary hard disk drive
A secondary hard disk drive might be placed on the inside front of the computer.
Image of the secondary disk drive inside the computer
If replacing a secondary hard disk drive, remove the drive using the following steps. Otherwise, if adding a new secondary hard disk drive, see Add or replace a secondary drive..
Step 1
Step 2
Remove the screws that secure the hard disk drive to the front of the computer.
Four screws at the front of computer
Step 3
Lift the hard drive and detach the power cable. The serial ATA power connector has a latch that must be squeezed to remove the connector.
Data connector being removed from the hard drive
Power connector tab being squeezed
Step 4
Detach the data cable from the rear of the drive. The serial ATA data connector has a latch that must be squeezed to remove the connector, then...
...remove the hard drive from the computer.
Data connector being removed from the disk drive
Data connector tab being squeezed
Adding or replacing a secondary hard disk drive
Use the following steps to add or replace a secondary hard disk drive.
Step 1
Attach the power and data connectors to the hard disk drive.
Replacing the connectors on the hard disk drive
Step 2
Place the hard drive against the inside front wall of the computer.
Hard drive placed inside front of computer
Step 3
Align the four screw holes on the underside of the drive with the four holes on the front of the computer. Attach the screws.
If the hard drive is being added, attach the data cable to the motherboard.
Replacing the screws
Step 4
