HP xw4600 Workstation Product Specifications
he HP xw4600 pictured with two displays
Product features
Feature
Form factor
Convertible minitower
Processors
  • Intel Pentium Dual-Core3 E2180 (Dual-Core3 2.00-GHz, 1MB L2 cache, 800 MHz FSB)
  • Intel Core 2 Duo E4500 (Dual-Core3 2.20-GHz, 2MB shared L2 cache, 800 MHz FSB)
  • Intel Core 2 Duo E6550 (Dual-Core3 2.33-GHz, 4MB shared L2 cache, 1333 MHz FSB)
  • Intel Core 2 Duo E6750 (Dual-Core3 2.66-GHz, 4MB shared L2 cache, 1333 MHz FSB)
  • Intel Core 2 Duo E6850 (Dual-Core3 3.00-GHz, 4MB shared L2 cache, 1333 MHz FSB)
  • Intel Core 2 Quad Q6600 (Quad-Core3 2.40-GHz, 2 x 4MB shared L2 cache, 1066 MHz FSB)
  • Intel Core 2 Quad Q6700 (Quad-Core3 2.66-GHz, 2 x 4MB shared L2 cache, 1066 MHz FSB)
  • Intel Core 2 Extreme Processor QX6850 (Quad Core 3.00-GHz, 2 x 4MB shared L2 cache, 1333 MHz FSB)
Actual bus clock rate is less. Listed bus speed represents the effective data transfer rate.
Memory
PC2-6400 ECC Unbuffered DDR2-800 RAM:
  • HP 1GB (1x1GB) DDR2-800 non-ECC RAM
  • HP 1GB (1x1GB) DDR2-800 ECC RAM
  • HP 2GB (2x1GB) DDR2-800 non-ECC RAM
  • HP 2GB (2x1GB) DDR2-800 ECC RAM
  • HP 4GB (2x2GB) DDR2-800 ECC RAM
  • HP 4GB (4x1GB) DDR2-800 ECC RAM
  • HP 8GB (4x2GB) DDR2-800 ECC RAM
  • HP 8GB (2x4GB) DDR2-800 ECC RAM
  • HP 12GB (2x2GB, 2x4GB) DDR2-800 ECC RAM
  • HP 16GB (4x4GB) DDR2-800 ECC RAM
Only unbuffered DDR2 DIMMs are supported. All DIMMs must be either x8 or x16 width.
  • 1GB PC2-6400E DDR2-800 ECC
  • 2GB PC2-6400E DDR2-800 ECC
  • 4GB PC2-6400E DDR2-800 ECC
Only unbuffered DDR2 DIMMs are supported. All DIMMs must be either x8 or x16 width. Memory must be installed in pairs.
Intel X38 Express chipset
Hard Drive
Up to 4 drives (2 will require optional expander kits), 2 TB max.; 80, 160GB (10K rpm) SATA 1.5Gb/s; or 80, 160, 250, 500GB (7200 rpm) SATA 3Gb/s NCQ; or 73, 146, 300GB (15K rpm) SAS 3Gb/s
Optical drives
DVD-ROM (SATA); DVD/CD-RW combo (SATA); DVD+/-RW Double Layer SuperMulti (SATA) with LightScribe Direct Disc Labeling (Microsoft Windows only, requires LightScribe media for labeling); 16-in-1 Media Card Reader (occupies lowest Optical Bay)
Drive bays
3 external 5.25 in bays (opt. CRU dataport enclosure enables 3.5 in SATA hard drive to be added to 5.25 in bay, not available in all regions),- 2internal 3.5 in bays, 1 external 3.5 in bay
Slots
7 full length slots: 2 PCI Express (PCIe) x16 graphics, 1 PCIe x8 (x4 electrical) slot, 1 PCIe x1 slot, 3 PCI slots
Graphics
  • Professional 2D: NVIDIA Quadro NVS290 (256MB, up to two cards) and NVIDIA Quadro NVS440 (256MB, can be used in dual configuration with NVS290) (expected availability Q1, 2008)
  • Entry 3D: NVIDIA Quadro FX370 (256MB, up to two cards) and NVIDIA Quadro FX570 (256MB, up to two cards)
  • Mid-range 3D: ATI FireGL V5600 (512MB) and NVIDIA Quadro FX1700 (512MB, up to two cards) High-end 3D: NVIDIA Quadro FX3500 (256MB), NVIDIA Quadro FX 4600 (512MB)
Audio
Integrated high definition audio with jack retasking capability, opt. PCI Sound Blaster X-Fi XtremeGamer
Input Devices
  • PS/2 standard keyboard
  • USB standard keyboard
  • USB Smart Card Keyboard
  • PS/2 2-button optical scroll mouse
  • USB 2-button optical scroll mouse
  • USB 3-button optical mouse
  • USB SpaceExplorer; USB SpacePilot
Network
Integrated Broadcom 5755 NetXtreme Gigabit PCIe, opt. Broadcom 5751 NetXtreme Gigabit PCIe
Ports
  • Front: 2 USB 2.0, 1 headphone, 1 microphone, IEEE 1394 (optional),
  • Rear: 7 USB 2.0, 1 standard serial port (opt. 2nd), 1 parallel, 2 PS/2, 1 external SATA 1.5Gb/s, 1 RJ-45 to integrated Gigabit LAN, audio in, audio out, microphone
  • Internal: 3 USB 2.0
Dimensions (H x W x D)
17.7 in (44.9cm) x 6.7 in (17.0cm) x 18.0 in (45.7cm)
Power
475 W; active Power Factor Correction
Compliance and regulatory
80 PLUS efficient; ENERGY STAR qualified configurations
Monitors (diagonally measured)
19 in HP LP1965 Flat Panel Monitor, 20.1 in HP LP2065 Flat Panel Monitor, 24 in HP LP2465 Flat Panel Monitor, 30 in HP LP3065 Flat Panel Monitor
Limited three-year next business day, parts, labor and 8x5 phone support; Terms and conditions may vary, certain restrictions apply. Service levels and response times for HP Care Packs may vary depending on your geographic location. Restrictions and limitations apply. For details, visit :www.hp.com/go/carepack.
Hardware specifications
Features
Chassis Dimensions (HxWxD)
Standard minitower orientation: 6.6 x 17.9 x 17.7 inches; 16.8 x 45.6 x 45.0 cm.
Minimum: 29.9 lbs (13.6 kg)
Standard: 33.3 lbs (15.1 kg)
Maximum: 43.3 lbs (19.6 kg)
Temperature
Operating: 40 degree to 95 degree F (5 degree to 35 degree C).
Non-operating: -40 degree to 140 degree F (-40 degree to 60 degree C).
Relative Humidity
Operating: 8% to 85%.
Non-operating: 8% to 90%.
Altitude (unpressurized)
Operating: 10,000 feet; 3,000 m.
Non-operating : 30,000 feet; 9,100 m.
Power Supply
475 W wide-ranging, active Power Factor Correction, 80 PLUS Efficient Surge immunity up to 2000V.
Communications
Features
Broadcom BCM5755 NetXtreme Gigabit Ethernet Network Controller LoM
Controller: Broadcom 5755 PCI-E LAN Controller.
Memory: Integrated 48KB receive buffer and 8KB transmit buffer
Intel Pro 1000 PT PCI Express Gigabit NIC
Controller: Intel 82572EI Gigabit Ethernet Controller.
Memory: Integrated Dual 48K configurable transmit receive FIFO Buffers.
Broadcom BCM5751 NetXtreme Gigabit Ethernet Controller
Controller: Broadcom 5751 PCI-E 1.0a LAN Controller.
Memory: Integrated 96Kb frame buffer memory.
Agere Systems PCI International Softmodem
Data Transmission: Technology speeds: 56,000 Kbps maximum downstream data, controllerless.
56 Kbps technology refers to download speeds only and requires compatible modems at server sites. Other conditions may limit modem speed. FCC limitations allow a maximum of 53 Kbps during download transmissions.
Audio and graphics
Features
Audio
  • HP Thin USB Powered Speakers.
  • Integrated High Definition audio with internal speaker.
  • SoundBlaster X-Fi XtremeGamer Audio Card.
Graphics
  • NVIDIA Quadro NVS 440, 256 MB Quad Head.
  • NVIDIA Quadro NVS 290, 256 MB Dual Head.
  • NVIDIA Quadro FX 370 PCI-Express graphics controller.
  • NVIDIA Quadro FX 570 PCI-Express graphics controller.
  • NVIDIA Quadro FX 1700 PCI-Express graphics controller.
  • ATI FireGL V5600 PCI-Express graphics controller.
  • NVIDIA Quadro FX 3700 PCI-Express 2.0 graphics board .
  • NVIDIA Quadro FX 4600 (768 MB).
Software overview
Feature
Operating System
Genuine Windows Vista Business 32-bit Genuine Windows Vista Business 64-bit Genuine Windows Vista 32-bit downgrade to Genuine Microsoft Windows XP Professional 32-bit5 Genuine Windows Vista 64-bit downgrade to Genuine Microsoft Windows XP Professional 64-bit (available Q1, 2008) 5 Red Hat Enterprise Linux WS 4 64-bit HP Installer Kit for Linux (includes drivers for both 32-bit & 64-bitOS versions of Red Hat Enterprise Linux WS4 and WS5) Red Flag Linux v5 (available in China only)
