Printer Specifications for the HP Officejet Pro L7380 All-in-One Printer
Figure : HP Officejet Pro L7380 All-in-One
Product models
Printer Number
Product Number
HP OfficeJet Pro L7380 All-in-One
CB778A
Minimum System Requirements
Windows system requirements
Component
Minimum
Recommended
Windows 2000, Windows XP, Windows XP 64-bit (Professional and Home Editions)
Processor
Windows 2000: Intel Pentium II or Celeron processor
Windows XP 64-bit edition: Intel Pentium II or Celeron processor
Windows 2000: Intel Pentium III or higher processor
Windows XP 64-bit edition: Intel Pentium III or higher processor
RAM
128 MB
256 MB
Free disk space
280 MB free hard disk space for software installation
Full-color scanning requires an additional 50 MB hard disk space
400 MB free hard disk space for software installation
Video display
SVGA 800 x 600 monitor with 16-bit color or higher
Connectivity
USB 2.0-compliant high speed
Internet Explorer version
Internet Explorer 6.0
Internet Explorer 6.0 or later
Macintosh system requirements
Component
Minimum
Recommended
Mac OS X 10.3.9 or higher
Processor
333 MHz
333 MHz
RAM
128 MB
256 MB
Free disk space
100 MB
200 MB
Video display
800 x 600, 16-bit or higher
Connectivity
USB 2.0 full speed, front and back ports
Environmental specifications
  • Recommended operating temperature range: 15° to 35° C (59° to 95° F)
  • Allowable operating temperature range: 5° to 40° C (41° to 104° F)
  • Humidity: 15 to 80% non-condensing
  • Non-operating (storage) temperature range: minus 40 to 60 degrees Celsius (minus 40 to 140 degrees Fahrenheit)
  • In the presence of high electromagnetic fields it is possible that the output from the HP Officejet may be slightly distorted
    HP recommends using a USB cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields
Physical dimensions
Dimension
Value
Height
273.05 mm (10.75 inches)
Width
496 mm (19.5 inches)
Depth
403.2 mm (15.9 inches)
9.7 kg (21.4 lb)
Energy Star
Energy usage drops significantly while in ENERGY STAR mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR, which is a voluntary program established to encourage the development of energy-efficient office products.
Figure : Energy Star
Energy Star logo
ENERGY STAR is a U.S. registered mark of the U.S. EPA. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency. For more information, go to www.energystar.gov.
Cartridges
Printing specifications
  • Print method: Drop-on-demand thermal inkjet printing
  • Device languages: HP PCL 3 enhanced
  • Print speed (varies by model): Up to 20 pages per minute (ppm) black after first page / up to 13 ppm color after first page (See www.hp.com/go/inkjetprinter for details. )
  • Print speeds vary according to the complexity of the document
  • Print resolution: Up to 1200 dpi with pigmented black ink / up to 4800 by 1200 dpi optimized on HP Premium Plus photo papers with 1200 by 1200 input dpi
  • Duty cycle: Up to 7500 pages per month
Mode
Type
Speed (ppm)
Draft mode
Black text
*up to 37 after first page
Mixed text with color graphics
*up to 32 after first page
Normal
Black text
*up to 16 after first page
Best
Black text
*up to 5 after first page
Laser quality speed
Black text
*up to 12 after first page
*up to 10 after first page
Copying specifications
  • Digital image processing
  • Up to 99 copies form original (varies by model)
  • Digital zoom: from 25 to 400% (varies by model)
  • Fit to page, pre-scan
  • Copy speeds vary according to the complexity of the document
Mode
Type
Speed (ppm).
Scan resolution (dpi) (maximum at 400% scaling)
Best
Black
up to .85
up to 600 x 1200
Color
up to .75
up to 600 x 1200
Normal
Black
up to 4.1
up to 300 x 300
Color
up to 2.8
up to 300 x 300
Fast
Black
up to 20
up to 300 x 300
Color
up to 13
up to 300 x 300
Paper and Plastic use
This product is suited for the use of recycled paper according to the DIN 19309 and EN 12281:2002. Plastic parts over 25 grams are marked according to the international standards that enhance the ability to identify plastics for recycling purposes at the end of product life.
Paper tray capacity
Tray
Type
Capacity
Tray 1
Paper
60 to 105 g/m2 (16 to 28 lb bond)
Up to 250 sheets of plain paper (25 mm or 1 inch stacked)
Transparencies
Up to 70 sheets (17 mm or 0.67 inch stacked)
Photo paper
280 g/m2 (75 lb bond)
Up to 100 sheets (17 mm or 0.67 inch stacked)
Labels
Envelopes
75 to 90 g/m2 (20 to 24 lb bond envelope)
Up to 30 sheets (17 mm or 0.67 inch stacked)
Cards
Up to 200 g/m2 (110 lb index)
Up to 80 cards
Output tray
All supported media
Up to 150 sheets of plain paper (text printing)
1 Maximum capacity.
2 Output tray capacity is affected by the type of paper and the amount of ink you are using. HP recommends emptying the output tray frequently.
Paper types supported
Type
Size
Paper
Letter: 216 x 280 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm
Envelopes
U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
U.S. 9: 98 x 225 mm (3.9 x 8.9 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency film
Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Premium Photo Paper
102 x 152 mm (4 x 6 inches)
A4: 210 x 297 mm
Cards
A6: 105 x 148.5 mm
Index card: 76 x 127 mm (3 x 5 inches)
Index card: 101 x 152 mm (4 x 6 inches)
Labels
A4: 210 x 297 mm
Custom
102 x 152 mm up to 216 x 356 mm (4 x 6 inches up to 8.5 x 14 inches)
Print margin specifications
Media
Type
Size (in mm)
Size (in inches)
Paper
US Letter
215.9 x 279.4 mm
8.5 x 11 inch
US Legal (20 lb and up)
1215.9 x 355.6 mm
8.5 x 14 inch
US Executive
184.2 x 266.7 mm
7.25 x 10.5 inch
ISO A4
210 x 297 mm
8.27 x 11.7 inch
JIS B5
182 x 257 mm
7.2 x 10.1 inch
ISO A5
148 x 210 mm
5.8 x 8.3 inch
Envelopes
#10
104.8 x 241.3 mm
4.125 x 9.5 inch
DL
110 x 220 mm
4.33 x 8.66 inch
C6
114 x 162 mm
4.49 x 6.38 inch
A2 (5.5 baronial)
111 x 146 mm
4.37 x 5.75 inch
Cards
3 x 5 Index Card
76.2 x 127 mm
3 x 5 inch
Hagaki Post Card
100 x 148 mm
3.94 x 5.83 inch
4 x 6 Index Card
101.6 x 152 mm
4 x 6 inch
ISO A6
105 x 148.5 mm
4.13 x 5.85 inch
Index Card
127 x 203.2 mm
5 x 8 inch
US-Letter
215.9 x 279.4 mm
8.5 x 11 inch
Media
Top (TM)
Left (LM)
Right (RM)
Bottom (BM)
U.S. Letter, U.S. Legal, A4, U.S. Statement, 8.5 x 13 inch, customized media, photo media
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
U.S. Executive, B5, A5, cards
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
Envelopes
3.3 mm (0.13 inch)
3.3 mm (0.13 inch)
16 mm (0.63 inch)
16 mm (0.63 inch)
Power consumption
  • Power consumption:40 W (average printing)
  • Idle state power consumption: 5.593 W
  • Input voltage: 100 to 240 VAC (± 10 %), 50/60 Hz (± 3Hz)
  • Output voltage: 32 Vdc, 2500 mA
Scanning specifications
  • Image editor included
  • Integrated OCR software automatically converts scanned text to editable text
  • Twain compliant interface
  • Scan speeds vary according to the complexity of the document
  • Resolution: 1200 x 2400 dpi optical, up to 19,200 dpi enhanced
  • Color: 16-bit per RGB; 48 bit total
  • Maximum scan size from the glass: 216 x 297 mm (8.5 x 11.7 inches)
