HP BladeSystem bc2800 Blade PC - Specifications
Hardware Specifications
Features
Dimensions (HxWxD)
With stand 4.7 inches (11.94 cm) x 0.8 inches (2.03 cm) x 15.5 inches (39.37 cm).
2.2 lb (1.0 kg).
Temperature*
Operating: 50 degree to 95 degree F (10 degree to 35 degree C).
Non-operating: –40 degree to 140 degree F (–40 degree to 60 degree C).
Note * - Operating temperature has an altitude derating of 34 degree F (1 degree C) per 1,000 ft (304.8 m). No direct sunlight. Storage maximum humidity of 95% is based on a maximum temperature of 112 degree F (45 degree C). Minimum pressure for storage is 70 KPa.
Relative humidity (non-condensing)
Operating: 10% to 90%.
Non-operating : 10% to 90%.
Communications
Features
Broadcom 5906M 10/100 Integrated NIC
Network interface: 10Base-T/100Base-TX.
Compatibility: IEEE 802.3/802.3u compliant.
HP BladeSystem PC Blade Switch
Port configuration:
  • 42 10/100BASE-T ports.
  • 4 RJ-45 10/100/1000BASE-T ports.
  • 4 SFP slots for fiber media support.
  • 802.3u and 802.3ab Auto-negotiation for speed, duplex mode and 802.3x flow control; Auto MDI/MDIX on uplink ports.
  • Port mirroring; Broadcast storm control; Cable Tester.
HP BladeSystem PC Blade RJ-45 Patch Panel
Port configuration:
  • 20 RJ-45 connectors for Blade PC NIC A (PXE-enabled).
  • 20 RJ-45 connectors for Blade PC NIC B (not PXE-enabled).
  • 1 Integrated Administrator management connector (10/100 Ethernet).
  • 1 Integrated Administrator console connector (RS-232 serial).
Security
  • Administrator's password.
  • NX Security Support.
