HP PSC 1600 and 2350 All-in-One Series - 'Incompatible Print Cartridge' Error Message Appears on the Control Panel Display
This document is for the HP PSC 1600 and 2350 All-in-One printers.
The Incompatible Print Cartridge error message appears on the product control panel display and the product does not print.
HP recommends that you use genuine HP ink or toner supplies. HP cannot guarantee the quality or reliability of non-HP or refilled cartridges. If you do not use genuine HP cartridges, the steps in this document might not resolve the issue. To check the authenticity of your cartridges, go to hp.com/go/anticounterfeit.
If the cartridge is not compatible with the product, obtain the correct cartridge and then go to "Solution five: Replace the cartridge." If the cartridge is compatible, continue to "Solution two: Download and install an update from HP."
There is an update that prevents an error that can render the cartridges unusable. If a cartridge failure has already occurred, download and install this update now to try to resolve the issue.
The update is not available for computers with the Vista operating system. If the computer operating system is Vista, go to "Solution three: Remove and then reinsert the cartridge" now.
The HP product software must be installed before installing this update. If the product software is not already installed, install it now. Follow these instructions to download and install the update.
Step one: Download the update
  1. Make sure that the product is turned on and connected to the computer.
  2. Hold down the Shift key and click here to open the Software and driver download page in another window.
  3. Under Locate your product to get support, type the product model and then click Next.
  4. If necessary, click the product number under Select your product from the list below.
  5. Under Select your operating system, click the appropriate operating system.
  6. On the Software and driver download page, in the Update section, click Resolves certain print cartridge rejection and scanner failure error messages.
Step two: Install the update
  1. Follow the on-screen instructions to install the update.
  2. If a device update error screen or another error screen appears, restart the computer and try to install the update again. The update might fail if it has already been applied.
  3. After installing the update, make sure that the product is turned on and loaded with paper.
  4. Try to print a document.
If the issue persists, see the next solution.
If the error message indicates that a specific cartridge is the issue, use these steps to remove and reinsert that cartridge. If the error message is not specific about one cartridge, follow these steps for each cartridge.
Step one: Open the product and remove the cartridge
  1. Make sure that the product is turned on. Press the power button () if it is not lit.
  2. Open the cartridge access door and wait until the carriage is idle and silent.
  3. Press down lightly on the end of each cartridge to release it.
    • The tri-color cartridge is on the left.
    • The black or photo cartridge is on the right.
    Figure : Remove the tri-color cartridge
  4. Slide the cartridge out.
    Do not keep the cartridge outside the product for more than 30 minutes. The ink can dry and clog the nozzles if the cartridge is outside the product for too long.
  5. After removing the cartridge, unplug the power cord from the rear of the product. Wait 30 seconds to 1 minute.
  6. Reconnect the power cord.
Step two: Reinstall the cartridge
  1. Hold the cartridge so that the nozzles are down and the contacts face the product. Slide the cartridge into the carriage.
    • Cartridges marked with a triangle go into the left carriage slot.
    • Cartridges marked with a square or pentagon go into the right carriage slot.
    Figure : Slide the cartridge into the carriage
  2. Push the cartridge forward until it snaps into place.
    Figure : Push the cartridge into place
  3. Close the cartridge access door.
  4. Make sure that the product is turned on and loaded with paper.
  5. Try to print a document.
Solution four: Check and clean the cartridge
If the error message indicates that a specific cartridge is the issue, use these steps to check and clean that cartridge. If the error message is not specific about one cartridge, use these steps to check and clean each cartridge.
Step two: Make sure that the protective tape has been removed from the cartridge
Make sure that the protective tape has been removed. Use the pink pull-tab to remove the protective tape from the cartridge.
    Figure : Remove the protective tape
  1. Pull-tab
Step three: Clean the cartridge
  1. Gather the following items to clean the contacts on the cartridge and in the carriage.
    • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water might contain contaminants that could damage the cartridge.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
    • Sheets of paper or paper towel to rest the cartridges on during cleaning.
  2. Place the cartridge on a piece of paper with the nozzle plate facing up.
  3. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
  4. Clean the cartridge contacts. Do not touch the nozzles.
      Figure : Clean the electrical contacts
    1. Electrical contacts
    2. Nozzles
  5. Clean the contacts in the carriage inside the product. The carriage contacts are copper and are located in the carriage so that they align with the cartridge contacts when the cartridge is installed.
  6. Wipe the cleaned area with a dry swab to remove any moisture.
Step four: Reinstall the cartridge
If the error message indicates that a specific cartridge is the issue, use these steps to replace that cartridge with a new one. If the error message is not specific about one cartridge, use these steps to replace each cartridge with a new one.
Step one: Open the product and remove the old cartridge
    Figure : Remove the cartridge
Step two: Make sure that the protective tape has been removed from the new cartridge
Remove the protective tape from the new cartridge. Use the pink pull-tab to remove the protective tape.
Do not attempt to remove the copper strip.
  1. Pull-tab
After the tape is removed, do not touch the copper contacts or the ink nozzles.
    Figure : Contacts and nozzles
  1. Contacts
  2. Nozzles
Step three: Install the new cartridge
Solution six: Check the carriage
Use the following steps to make sure the carriage can move freely.
  1. With the product turned on, open the cartridge access door. The carriage might try to move into the access area. Allow it to move to that position.
  2. Without turning off the product, disconnect the power cord from the back of the product to reset the print mechanism and allow the moving of parts by hand.
      warning:
    The following steps require you to move parts by hand. There is a risk of electrical shock if the power cord in not unplugged.
  3. Disconnect the power cord from the wall outlet.
  4. Look in through the cartridge access door or the output paper tray to make sure the cartridges are secure in the carriage and have not come loose.
  5. Check for any obstructions under or around the carriage that are preventing it from moving.
  6. Make sure the carriage can move freely across the width of the product by firmly pushing the carriage to the left, and then to the right.
  7. Clear any obstructions. You might have to reach through the output paper tray to access the carriage.
  8. Close the cartridge access door.
  9. Reconnect the power cord to the back of the product and to the wall outlet.
  10. Press the power button () to turn on the product and make sure that there is paper loaded in the product.
  11. Try to print a document.
Solution
There are several possible solutions to this issue. Start with "Solution one: Make sure that the cartridge is compatible with the product" and then continue with each solution in the order presented until the issue is resolved.
If you have completed all of the steps listed above and are still experiencing a problem, service your product.
