HP Compaq dc7900 Convertible Minitower PC - Removing and Replacing the CPU Fan
This document is provided to assist in removing and replacing the CPU Fan for the HP Compaq dc7900 Convertible Minitower PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Parts required
The replacement part number will vary depending on the CPU Fan that is being replaced. If a part is listed as 'Yes' under 'Requires Return' then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Fan/heatsink assembly
455310-001
No
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the CPU Fan, click on the link below. Or use the product video listing on the HP Services Media Library, then select CPU Fan from the menu on the upper left hand side of the screen.
Click here to view the CPU Fan removal video (right-click on the link to open in a new window/tab).
CPU Fan removal
  2. Remove the access panel and heat sink. Click here for instructions to remove the Access Panel
  3. Disconnect the CPU fan cable from the system board.
  4. Press the release tab at the top of the CPU fan holder and slide it up to disengage it from the CPU fan bracket.
  5. Remove the CPU fan holder and CPU fan.
  6. Flex the four retention tabs on the CPU fan holder to disengage the CPU fan from the fan holder.
  7. Lift the CPU fan off of the fan holder.
CPU Fan replacement
  1. Position the CPU fan in the correct orientation over the guide pins on the fan holder.
    The CPU fan must be installed in the correct orientation for proper air cooling. Make sure the air flow arrow located on one side of the CPU fan is pointing in the same direction as the arrow on the CPU fan holder release tab.
  2. Press the CPU fan into the fan holder until it snaps into place.
  3. Align the fan holder with the slots on the CPU fan bracket.
  4. Press the release tab and slide the fan holder down until the release tab aligns with the slot in the CPU fan bracket and then release the tab.
  5. Connect the CPU fan cable to the system board.
Parts return
