HP Compaq dc5800 Small Form Factor PC - Removing and Replacing the Hard Drive
This document is provided to assist in removing and replacing the Hard Drive for the HP Compaq dc5800 Small Form Factor PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Parts required
The replacement part number will vary depending on the Hard Drive that is being replaced. If a part is listed as 'Yes' under 'Requires Return' then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
80 GB SATA 1.5 Gb/s hard drive
439994-001
Yes
160 GB SATA 1.5 Gb/s hard drive
439995-001
Yes
80 GB SATA 2 (3 Gb/s) hard drive
440754-001
Yes
449978-001
Yes
160 GB SATA 2 (3 Gb/s) hard drive
440499-001
Yes
449979-001
Yes
250 GB SATA 2 (3 Gb/s) hard drive
440747-001
Yes
449980-001
Yes
500 GB SATA 2 (3 Gb/s) hard drive
457909-001
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the Hard Drive, click on the link below. Or use the product video listing on the Services Media Library, then select Hard Drive from the menu on the upper left hand side of the screen.
Click here to view the Hard Drive removal video (right-click on the link to open in a new window/tab).
Hard Drive removal
  2. Rotate the drive cage to the up position.
  3. Rotate the power supply to the up position.
  4. Disconnect the power and data cables from the back of the drive.
  5. While pressing on the drive release latch, slide the drive forward and up out of the drive bay.
    If the replacement drive does not include guide screws, remove and reuse the screws from this drive.
Hard Drive replacement
  1. Align guide screws on the drive with the J-slots on the drive bay.
  2. Push the drive into the drive bay and then slide it back until it locks into place.
  3. Connect the data and power cables to the drive.
  4. Lower the power supply to the down position.
  5. Lower the drive cage to the down position.
Parts return
