HP Compaq 6735s Notebook PC - Removing and Replacing the Hard Disk Drive
This document is provided to assist in removing and replacing the Hard Disk Drive for the HP Compaq 6735s Notebook PC.
Minimum skill level
Tools required
Phillips-head P1 screwdriver.
Parts required
The replacement part number will vary depending on the Hard Disk Drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
250 GB SATA hard disk drive - 5,400 RPM, 2.5 inches form factor, 9.5mm height - Includes bracket
491598-001 (Modified)
Yes
160 GB SATA hard disk drive - 5,400 RPM, 2.5 inches form factor, 9.5mm height - Includes bracket
491597-001 (Modified)
Yes
120 GB SATA hard disk drive - 5,400 RPM, 2.5 inches form factor, 9.5mm height - Includes bracket
491596-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the Hard Disk Drive, click on the link below. Or use the product video listing on the HP Services Media Library then select Hard Disk Drive from the menu on the upper left hand side of the screen.
Click here to view the Hard Disk Drive removal video (right-click on the link to open in a new window/tab).
  2. Loosen the two captive P1 Phillips-head screws that secure the hard disk drive cover to the bottom of the notebook.
  3. Lift the hard disk drive cover and remove it.
  4. Loosen the captive P1 Phillips-head screw that secures the hard disk drive to the base enclosure.
  5. Grasp the Mylar tab and pull the hard disk drive from the system board connector.
  6. Lift the hard disk drive out of the drive bay.
  7. Place the hard disk drive in a static dissipative bag.
Hard Disk Drive replacement
  1. Remove the hard disk drive from the static dissipative bag.
  2. Place the hard disk drive into the drive bay and align it with the system board connector.
  3. Grasp the Mylar tab and slide the hard disk drive into the connector until it is firmly seated.
  4. Tighten the captive P1 Phillips-head screw that secures the hard disk drive to the base enclosure.
  5. Toe the hard disk drive cover into the base enclosure.
  6. Tighten the two captive P1 Phillips-head screws.
Parts return
